New Firmware available for RV340 Series Router family! This includes the RV340, RV340W, RV345, and RV345P
To learn more and get the latest Firmware version click here.
136
Highlighted
Beginner
RV180 IPSEC from Android
I am getting this problem when trying to connect to ipsec vpn
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] INFO:  Received attribute type "ISAKMP_CFG_REPLY" from 46.135.70.24[32684]
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] INFO:  Login succeeded for user  "admin"
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] INFO:  XAuthUser admin Logged In from IP Address 46.135.70.24
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] INFO:  Received attribute type "ISAKMP_CFG_REQUEST" from 46.135.70.24[32684]
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] ERROR:  Local configuration for 46.135.70.24[32684] does not have mode config
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] WARNING:  Ignored attribute 28678
Thu May 08 08:10:09 2014 (GMT +0100): [routerBB9298] [IKE] INFO:  Sending Informational Exchange: notify payload[10381]
Does anyone have idea what is wrong? What means this  Local configuration for 46.135.70.24[32684] does not have mode config?
View:
Selected IKE Policy View
General
Policy Namexxxxxxx
Direction / TypeBoth
Exchange ModeAggresive
Enable XAUTH Client
Local Identification
Identifier TypeFQDN
FQDNlocal.com
Peer IKE Identification
Identifier TypeFQDN
FQDNremote.com
IKE SA Parameters
Encryption Algorithm3DES
Authentication AlgorithmSHA-1
Authentication MethodPre-Shared Key
Pre-Shared Keyxxxxxxxx
Diffie-Hellman (DH) GroupGroup 2 (1024bit )
SA-Lifetime28800 Seconds
Thank you in advance
Peter
Contributor
I found that ipsec doesn't
I found that ipsec doesn't work because the IP of the phone is always changing. Try using the PPTP option and see if that works.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
Beginner
Hi Samir, Yes pptp is no
Hi Samir,
Yes pptp is no problem. But i wanted ipsec :(
Contributor
Ipsec won't work because of
Ipsec won't work because of the IP address issue.  Sorry. :(
Ask the Expert- Firepower configuration & troubleshooting
