RV180 - Multiple VLAN Speed Problem
taylor1437
I have 3 VLANs setup on RV180, and the WAN connection speed provided by the ISP is 100Mbps.
By using a speed test service tool (e.g. speedtest.net), I get the following result :-
VLAN 1 - ~90Mbps
VLAN 2 - ~50-60Mbps
VLAN 3 - ~50-60Mbps
Anyone getting the same problem as me ?
And once I remove all VLANs setting, all 4 ports can reach the speed around 90Mbps again ... So I believe it should be the VLAN setting or software problem, any fix here ?
Thank you so much in advance.
Taylor
0 Replies 0
