Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
554
RV180 : NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1
On the RV180W a nonstop stream of reports is logged. Also wan access is sluggish or not reponding.
Our LAN is 172.16.0.0/23.
Example:
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=188.40.60.242 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=63897 DF PROTO=TCP SPT=9001 DPT=39296 WINDOW=388 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=69.164.195.240 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=39497 DF PROTO=TCP SPT=9001 DPT=60289 WINDOW=355 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=69.164.195.240 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=39498 DF PROTO=TCP SPT=9001 DPT=60289 WINDOW=355 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=167.114.3.144 LEN=800 TOS=0x00 PREC=0x00 TTL=63 ID=35201 DF PROTO=TCP SPT=9001 DPT=42634 WINDOW=225 RES=0x00 ACK PSH URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.720000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=168.235.154.96 DST=85.0.87.148 LEN=178 TOS=0x00 PREC=0x00 TTL=51 ID=33841 DF PROTO=TCP SPT=47099 DPT=9001 WINDOW=240 RES=0x00 ACK PSH URGP=0
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=69.164.195.240 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=39499 DF PROTO=TCP SPT=9001 DPT=60289 WINDOW=355 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1984.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=217.25.221.57 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=20668 DF PROTO=TCP SPT=9001 DPT=57548 WINDOW=351 RES=0x00 ACK URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1984.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=69.164.195.240 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=39500 DF PROTO=TCP SPT=9001 DPT=60289 WINDOW=355 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1984.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=88.198.219.54 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=12286 DF PROTO=TCP SPT=9001 DPT=54901 WINDOW=363 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1985.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=74.120.12.135 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=1485 DF PROTO=TCP SPT=9001 DPT=45291 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1985.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=5.149.255.131 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=47050 DF PROTO=TCP SPT=9001 DPT=49043 WINDOW=225 RES=0x00 ACK URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1985.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=66.175.221.24 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=38715 DF PROTO=TCP SPT=9001 DPT=41324 WINDOW=225 RES=0x00 ACK URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1985.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=5.149.255.131 LEN=800 TOS=0x00 PREC=0x00 TTL=63 ID=47051 DF PROTO=TCP SPT=9001 DPT=49043 WINDOW=225 RES=0x00 ACK PSH URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1986.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=24.128.235.42 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65352 DF PROTO=TCP SPT=9001 DPT=56022 WINDOW=352 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1986.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=69.164.195.240 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=39501 DF PROTO=TCP SPT=9001 DPT=60289 WINDOW=355 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1986.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=24.128.235.42 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65353 DF PROTO=TCP SPT=9001 DPT=56022 WINDOW=352 RES=0x00 ACK FIN URGP=0 MARK=0x1
6 REPLIES 6
Beginner
Johanness, I have noticed the
Johanness,
I have noticed the /23 subnet. So how many user or devices are getting ip addresses and passing traffic on this router?
I fail to understand what a
I fail to understand what a subnet mask has to do with the root cause of the problem.,
Dear Ismael.The current
Dear Ismael.
The current layout with the same router is a 192.168.111.0/27 network:
Sun Apr 19 15:01:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420281.290000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6205 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:01:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420281.340000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18271 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:01:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420281.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18272 DF PROTO=TCP SPT=54924 DPT=443 WI
Sun Apr 19 15:01:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420281.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18273 DF PROTO=TCP SPT=54852 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420282.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18281 DF PROTO=TCP SPT=54895 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420282.720000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=41998 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420282.880000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6206 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420282.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.15 DST=195.143.229.67 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=14242 DF PROTO=TCP SPT=54747 DPT=443 WINDOW=0 RES=0x00 ACK RST URGP=0 MARK=0x1
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.000000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=41999 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.100000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44491 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.340000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18283 DF PROTO=TCP SPT=54861 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18284 DF PROTO=TCP SPT=54863 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18285 DF PROTO=TCP SPT=54862 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.540000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42000 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=45284 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18292 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18298 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.330000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44492 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18300 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.630000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42001 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18301 DF PROTO=TCP SPT=54924 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18302 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420285.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18307 DF PROTO=TCP SPT=54918 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420285.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18308 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420285.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18309 DF PROTO=TCP SPT=54905 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420286.050000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6207 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420286.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18310 DF PROTO=TCP SPT=54867 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420286.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18311 DF PROTO=TCP SPT=54920 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420286.800000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44493 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420286.820000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42002 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18323 DF PROTO=TCP SPT=54929 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18330 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18335 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18337 DF PROTO=TCP SPT=54870 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18339 DF PROTO=TCP SPT=54931 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18341 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18342 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18343 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420288.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18344 DF PROTO=TCP SPT=54922 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420288.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18345 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420289.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18346 DF PROTO=TCP SPT=54909 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420289.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=45427 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.190000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=81.30.152.25 DST=178.199.245.179 LEN=64 TOS=0x00 PREC=0x00 TTL=52 ID=50902 DF PROTO=TCP SPT=33624 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18354 DF PROTO=TCP SPT=54873 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18356 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18361 DF PROTO=TCP SPT=54875 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18362 DF PROTO=TCP SPT=54874 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18364 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18365 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18366 DF PROTO=TCP SPT=54879 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18367 DF PROTO=TCP SPT=54880 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18368 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18369 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420291.180000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42003 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420291.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18371 DF PROTO=TCP SPT=54924 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420291.750000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44494 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420291.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18372 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420292.400000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6208 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420292.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18373 DF PROTO=TCP SPT=54913 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420292.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18385 DF PROTO=TCP SPT=54933 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420292.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18392 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420292.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18398 DF PROTO=TCP SPT=54935 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420293.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18401 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420293.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18402 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420293.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18403 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420293.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18404 DF PROTO=TCP SPT=54883 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420293.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18405 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420294.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18406 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420294.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18407 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420295.210000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=81.30.152.25 DST=178.199.245.179 LEN=178 TOS=0x00 PREC=0x00 TTL=52 ID=50903 DF PROTO=TCP SPT=33624 DPT=9001 W
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420295.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18412 DF PROTO=TCP SPT=54916 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420295.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18419 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18426 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18427 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.360000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=212.51.159.55 DST=178.199.245.179 LEN=178 TOS=0x00 PREC=0x00 TTL=48 ID=27919 DF PROTO=TCP SPT=36543 DPT=9001
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18428 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18429 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18430 DF PROTO=TCP SPT=54885 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420297.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18432 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420297.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18433 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.050000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=83.168.200.204 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=48552 DF PROTO=TCP SPT=9001 DPT=39473 WINDOW=368 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.280000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.25.148.130 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=12313 DF PROTO=TCP SPT=53130 DPT=9001 W
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18445 DF PROTO=TCP SPT=54938 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18453 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18457 DF PROTO=TCP SPT=54918 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18459 DF PROTO=TCP SPT=54940 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18461 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.940000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=5.135.148.171 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=51 ID=0 DF PROTO=TCP SPT=9001 DPT=39202 WINDO
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420299.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18463 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420299.270000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18464 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420299.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18465 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420299.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=48377 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420299.920000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42004 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420300.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18466 DF PROTO=TCP SPT=54920 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420300.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18467 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420300.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18468 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420300.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18469 DF PROTO=TCP SPT=54887 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420301.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18478 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420301.640000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44495 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420301.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18484 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420301.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18485 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420301.960000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18486 DF PROTO=TCP SPT=54922 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420302.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18487 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420302.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18488 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420302.560000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.241.222.98 DST=178.199.245.179 LEN=64 TOS=0x00 PREC=0x00 TTL=51 ID=53045 DF PROTO=TCP SPT=443 DPT=43894 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18489 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14195 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14196 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18491 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14197 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18492 DF PROTO=TCP SPT=54889 DPT=443 WI
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14198 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18503 DF PROTO=TCP SPT=54942 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18510 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18516 DF PROTO=TCP SPT=54944 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18518 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18519 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18520 DF PROTO=TCP SPT=54924 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18521 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420305.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14199 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420305.100000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6209 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420305.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18523 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420305.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18524 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420306.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18525 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420306.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18526 DF PROTO=TCP SPT=54891 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14200 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.260000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18537 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18544 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18545 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18546 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18547 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420308.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18548 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:41 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420308.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18549 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:41 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420309.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18551 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:41 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420309.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18552 DF PROTO=TCP SPT=54895 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420309.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18564 DF PROTO=TCP SPT=54946 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18572 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18577 DF PROTO=TCP SPT=54948 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18579 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18580 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18581 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18582 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18583 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14201 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420311.200000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38492 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420311.420000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38493 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420311.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18585 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420311.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18586 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420311.880000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38494 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8231 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8232 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8233 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18587 DF PROTO=TCP SPT=54905 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.790000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38495 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18594 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420313.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8234 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420313.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18602 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420313.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18603 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420313.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18604 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420313.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18605 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18606 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.140000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8235 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18607 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.620000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38496 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18608 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.830000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1564 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.080000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1565 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.330000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1566 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18621 DF PROTO=TCP SPT=54950 DPT=443 WI
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18628 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.760000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18634 DF PROTO=TCP SPT=54952 DPT=443 WI
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.830000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1567 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18636 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18637 DF PROTO=TCP SPT=54909 DPT=443 WI
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18638 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8236 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18639 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.440000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2740 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18640 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.690000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2741 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.850000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1568 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18641 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420317.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18645 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420317.180000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2742 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420317.390000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42005 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420317.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18647 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.180000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2743 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.280000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38497 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18654 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14202 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18661 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18662 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.870000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1569 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420319.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18664 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420319.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18665 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420319.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18666 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420319.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18667 DF PROTO=TCP SPT=54913 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420320.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18668 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420320.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2744 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420320.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8237 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420320.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18669 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:53 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420320.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=50182 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.260000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18682 DF PROTO=TCP SPT=54955 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18692 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.410000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44496 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18695 DF PROTO=TCP SPT=54957 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.540000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=212.51.159.55 DST=178.199.245.179 LEN=64 TOS=0x00 PREC=0x00 TTL=48 ID=27920 DF PROTO=TCP SPT=36543 DPT=9001 W
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18697 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.760000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18698 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18699 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18700 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18701 DF PROTO=TCP SPT=54916 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18702 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18703 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.910000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1570 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420323.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18705 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420324.140000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2745 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420324.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18713 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420324.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18719 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420324.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18720 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420324.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18721 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18722 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.310000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18724 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.560000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.241.222.98 DST=178.199.245.179 LEN=798 TOS=0x00 PREC=0x00 TTL=51 ID=53046 DF PROTO=TCP SPT=443 DPT=43894 W
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.600000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38498 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18725 DF PROTO=TCP SPT=54918 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18726 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420326.180000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18727 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420326.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18728 DF PROTO=TCP SPT=54920 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420326.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18740 DF PROTO=TCP SPT=54959 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18751 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18754 DF PROTO=TCP SPT=54963 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65080 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18760 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65081 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18762 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.630000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65082 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18763 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18764 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65083 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18765 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8238 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18766 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18767 DF PROTO=TCP SPT=54922 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18768 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420329.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65084 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18776 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18783 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18784 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.510000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6210 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18785 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18786 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18787 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.990000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1571 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420331.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=83.168.200.204 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=48553 DF PROTO=TCP SPT=9001 DPT=39473 WINDOW=368 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420331.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65085 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420331.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18789 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420331.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18790 DF PROTO=TCP SPT=54924 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420331.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18791 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420332.100000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2746 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420332.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18803 DF PROTO=TCP SPT=54966 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420332.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18810 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420332.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18816 DF PROTO=TCP SPT=54968 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420333.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18818 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420333.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18819 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420333.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18821 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420333.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18822 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420333.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18823 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.150000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2426 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18825 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14203 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.390000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2427 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18826 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.630000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2428 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18827 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420335.120000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2429 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420335.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65086 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420335.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18835 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420335.960000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18842 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420335.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18843 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420336.090000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2430 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420336.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18844 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420336.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18845 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420336.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18846 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420337.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18850 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420337.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18853 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420337.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18854 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.050000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2431 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18867 DF PROTO=TCP SPT=54970 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18877 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18880 DF PROTO=TCP SPT=54973 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18882 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18883 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420339.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18885 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420339.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18887 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420339.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18888 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420339.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18889 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420340.220000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38499 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420340.270000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18890 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420340.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18891 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420341.480000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18899 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420341.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18906 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420341.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18907 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420341.950000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2432 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420342.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18908 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420342.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18909 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420342.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18910 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420342.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18911 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420343.270000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18913 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420343.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65087 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420343.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18914 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18926 DF PROTO=TCP SPT=54975 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18934 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18939 DF PROTO=TCP SPT=54977 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18941 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8239 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.630000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18942 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18943 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18944 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420345.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18946 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420345.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18947 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420346.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18948 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420346.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18949 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.150000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1572 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18960 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18967 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18968 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18969 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18970 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420348.020000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2747 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420348.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18971 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420348.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18972 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.000000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18973 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18975 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.770000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2433 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18987 DF PROTO=TCP SPT=54979 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18996 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19000 DF PROTO=TCP SPT=54981 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420350.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19002 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420350.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19003 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420350.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19004 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420350.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19005 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420351.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19006 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420351.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19008 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420351.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19009 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420352.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19010 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420352.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19017 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420353.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19025 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420353.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19026 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420353.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19027 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420353.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19028 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420353.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19029 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420354.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19030 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420354.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19031 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420355.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19033 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420355.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19045 DF PROTO=TCP SPT=54983 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420355.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19053 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420355.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19058 DF PROTO=TCP SPT=54985 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420355.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19060 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420356.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19061 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420356.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19062 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420356.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19063 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420356.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19064 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420357.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19069 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420357.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19070 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420357.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19071 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420358.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19079 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420358.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19085 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420358.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19086 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420359.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19088 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420359.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19089 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420359.480000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19090 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420359.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=176.10.99.207 LEN=178 TOS=0x00 PREC=0x00 TTL=63 ID=52591 DF PROTO=TCP SPT=48882 DPT=1414 WINDOW=279 RES=0x00 ACK PSH URGP=0 MARK=0x1
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420359.740000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=5.135.148.171 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=51 ID=0 DF PROTO=TCP SPT=9001 DPT=39202 WINDO
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420360.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19091 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420360.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19092 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420360.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65088 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420360.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19093 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420361.340000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19106 DF PROTO=TCP SPT=54988 DPT=443 WI
Sun Apr 19 15:02:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420361.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19113 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420361.480000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19119 DF PROTO=TCP SPT=54990 DPT=443 WI
Sun Apr 19 15:02:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420361.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19121 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420361.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19122 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420362.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19123 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420362.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19124 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420362.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19125 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420362.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=52805 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420362.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19126 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420363.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60641 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420363.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19128 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420363.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60642 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420363.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19129 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420363.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60643 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58358 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60644 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.400000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58359 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19136 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19143 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19144 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.900000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58360 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19145 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.140000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19150 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19151 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60645 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.390000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2434 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14204 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.890000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58361 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19152 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420366.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19153 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420366.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19154 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8714 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.140000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19167 DF PROTO=TCP SPT=54992 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.220000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19174 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19180 DF PROTO=TCP SPT=54994 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8715 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19182 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60646 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19183 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8716 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19184 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.880000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58362 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19185 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420368.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8717 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420368.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19186 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420368.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19187 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420368.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19188 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8718 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.150000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34894 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19190 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.430000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34895 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.440000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38500 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.940000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34896 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19197 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19204 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19205 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19206 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19207 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19208 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.010000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34897 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8719 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.360000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=204.9.55.71 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=47 ID=5759 DF PROTO=TCP SPT=50620 DPT=9001 WIND
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=176.10.99.207 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=52592 DF PROTO=TCP SPT=48882 DPT=1414 WINDOW=279 RES=0x00 ACK URGP=0 MARK=0x1
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19210 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.850000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58363 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60647 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19211 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420372.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19212 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420372.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19223 DF PROTO=TCP SPT=54996 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420372.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19233 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420372.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19236 DF PROTO=TCP SPT=54998 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.120000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34898 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19242 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19243 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19244 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19245 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19246 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420374.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19247 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420374.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19248 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420374.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19249 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420375.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8720 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420375.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22186 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420375.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22187 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420375.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22188 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420375.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19257 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19264 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22189 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19265 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19266 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19267 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19268 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8240 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22190 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.360000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34899 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19270 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=19708 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19271 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.750000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=19765 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19272 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420378.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=19798 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420378.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19284 DF PROTO=TCP SPT=55000 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420378.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19291 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420378.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19297 DF PROTO=TCP SPT=55003 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420378.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19299 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19300 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22191 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=20000 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19302 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19303 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19304 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.810000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58364 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.820000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2748 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:02:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420380.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19305 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420380.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19306 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420380.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19307 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420380.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60648 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420381.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=20324 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420381.260000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6211 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420381.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19316 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420381.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19322 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420381.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19323 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420382.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19324 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420382.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19325 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420382.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19326 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22192 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54042 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19331 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19332 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.500000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54043 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19333 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.170000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54044 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19344 DF PROTO=TCP SPT=55005 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19354 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19357 DF PROTO=TCP SPT=55007 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19359 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19360 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19361 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21355 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19363 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19364 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.510000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54045 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.820000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34900 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.960000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19365 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:02:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420386.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19366 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420386.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19367 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420387.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19375 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420387.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19382 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420387.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19383 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420388.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19384 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420388.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19385 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420388.200000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54046 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420388.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19386 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420388.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19387 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420389.180000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19389 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420389.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19390 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19402 DF PROTO=TCP SPT=55009 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19412 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19417 DF PROTO=TCP SPT=55011 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19419 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19420 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19421 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420391.000000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19422 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420391.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19423 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420391.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22193 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420391.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21190 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420391.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19426 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420392.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19428 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:03:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420392.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19429 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:03:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420392.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21251 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420392.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21377 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=22418 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19440 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19447 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.580000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54047 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19448 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21478 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19449 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420394.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19450 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420394.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19451 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420394.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19452 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420394.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19453 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420395.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19454 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420395.710000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58365 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420395.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21760 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.260000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19467 DF PROTO=TCP SPT=55014 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.340000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19477 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19480 DF PROTO=TCP SPT=55016 DPT=443 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19482 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19483 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.650000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2435 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19484 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19485 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19486 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:11 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420397.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19488 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:03:11 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420397.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19489 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:03:11 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420397.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19490 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:11 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420398.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60649 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420399.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19498 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420399.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19505 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420399.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19506 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420399.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19507 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420399.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19508 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19509 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.100000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31889 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21764 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.340000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31890 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.590000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31891 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.750000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19510 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.760000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19511 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19512 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420401.090000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31892 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.080000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31893 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.260000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19525 DF PROTO=TCP SPT=55019 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19535 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19538 DF PROTO=TCP SPT=55022 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19540 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19541 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19544 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.800000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34901 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19546 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19547 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19553 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19554 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.660000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=58 ID=55162 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.660000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55163 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.660000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=783 TOS=0x00 PREC=0x00 TTL=58 ID=55164 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.700000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=783 TOS=0x00 PREC=0x00 TTL=58 ID=55165 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19556 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.920000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55166 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.960000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55167 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420404.070000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31894 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420404.340000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54048 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420404.350000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55168 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420404.560000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55169 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420405.230000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55170 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:19 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420405.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19569 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:03:19 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420405.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19572 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420405.760000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55171 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420405.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19575 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.180000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19583 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19589 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19590 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19591 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19592 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.960000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55172 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.990000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55173 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420407.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22194 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420407.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19594 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420408.040000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31895 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420408.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55174 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420408.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19595 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420408.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19596 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420408.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=22797 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=24434 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19608 DF PROTO=TCP SPT=55047 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.130000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=212.51.159.55 DST=178.199.245.179 LEN=178 TOS=0x00 PREC=0x00 TTL=48 ID=27921 DF PROTO=TCP SPT=36543 DPT=9001
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19616 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.270000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19622 DF PROTO=TCP SPT=55049 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19624 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19625 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19626 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19627 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19628 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420410.500000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55175 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420410.560000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55176 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420410.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19629 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420411.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19631 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420412.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19632 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420412.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19633 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420412.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19634 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420412.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19635 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420413.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19650 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420413.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19653 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420413.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19654 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420414.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19657 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420414.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19658 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420414.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19659 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420415.360000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55177 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420415.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19661 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420415.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19662 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420415.990000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31896 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19674 DF PROTO=TCP SPT=55051 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19683 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=38.229.70.53 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=55 ID=51824 DF PROTO=TCP SPT=36160 DPT=9001 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19687 DF PROTO=TCP SPT=55065 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.340000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19689 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19690 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19691 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420417.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19692 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420417.530000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55178 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420417.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19694 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420417.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19695 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420418.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19704 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420418.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19707 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19717 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19718 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19719 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19723 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19730 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19732 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19740 DF PROTO=TCP SPT=55072 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19742 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19743 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19744 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19745 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9339 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19746 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19747 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.410000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9340 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.660000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9341 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19748 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9342 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.220000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=25553 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:37 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19750 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:37 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19751 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:37 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.490000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=15174 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:37 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19752 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:37 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.830000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=282 DF PROTO=TCP SPT=43826 DPT=9001 WIN
Sun Apr 19 15:03:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9343 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.280000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.239.201.196 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=112 ID=6846 PROTO=TCP SPT=55256 DPT=9030 WIN
Sun Apr 19 15:03:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.280000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=56649 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19753 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.880000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.241.222.98 DST=178.199.245.179 LEN=64 TOS=0x00 PREC=0x00 TTL=51 ID=53047 DF PROTO=TCP SPT=443 DPT=43894 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19781 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19782 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19783 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.980000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=18916 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420423.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19784 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420423.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19789 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420423.750000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19790 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420424.170000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9344 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420424.170000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=28173 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420424.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19791 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420424.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19800 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420424.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19803 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420425.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19805 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420425.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19806 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420425.530000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=1027 DF PROTO=TCP SPT=43826 DPT=9001 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420425.840000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54049 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420425.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19815 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19824 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19827 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19832 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19835 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19836 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19837 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19838 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19839 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19841 DF PROTO=TCP SPT=55080 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=27703 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19843 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19844 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19845 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19846 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420427.520000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58366 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420427.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19848 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420427.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19849 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420427.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19850 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420428.040000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=39467 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420428.180000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9345 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420428.750000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.73.242.142 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=44 ID=24684 DF PROTO=TCP SPT=443 DPT=36617 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.050000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19851 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19859 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19860 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19866 DF PROTO=TCP SPT=55079 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19868 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.310000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19875 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19880 DF PROTO=TCP SPT=55082 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19882 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19883 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19884 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19885 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420430.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19886 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420431.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19888 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420431.580000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55180 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420431.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19889 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420431.880000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31897 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19890 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19891 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19892 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19893 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:53 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19894 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:53 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.850000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=64619 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:53 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19895 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19896 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19907 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60650 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19914 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=176.10.99.207 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=52594 DF PROTO=TCP SPT=48882 DPT=1414 WINDOW=279 RES=0x00 ACK URGP=0 MARK=0x1
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.660000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=58 ID=55181 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19915 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:03:55 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420434.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19916 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:03:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420435.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19918 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:03:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420435.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19919 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420435.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19920 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420435.960000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19921 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.200000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9346 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19933 DF PROTO=TCP SPT=55085 DPT=443 WI
Sun Apr 19 15:03:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19940 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:03:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19944 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:03:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19947 DF PROTO=TCP SPT=55088 DPT=443 WI
Sun Apr 19 15:03:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19949 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:03:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.700000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34902 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19950 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420437.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19952 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420437.960000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19953 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420438.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19954 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22195 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.310000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19956 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.310000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19957 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19958 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19959 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19960 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420440.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19967 DF PROTO=TCP SPT=55090 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420440.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19974 DF PROTO=TCP SPT=55090 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420440.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19975 DF PROTO=TCP SPT=55090 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420440.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=30729 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420441.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19976 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420441.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19979 DF PROTO=TCP SPT=55090 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420441.650000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=212.51.159.55 DST=178.199.245.179 LEN=64 TOS=0x00 PREC=0x00 TTL=48 ID=27922 DF PROTO=TCP SPT=36543 DPT=9001 W
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.270000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=42157 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19980 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19981 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19982 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19992 DF PROTO=TCP SPT=55091 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20002 DF PROTO=TCP SPT=55093 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420443.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20005 DF PROTO=TCP SPT=55094 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20214 DF PROTO=TCP SPT=55117 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20215 DF PROTO=TCP SPT=55118 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20217 DF PROTO=TCP SPT=55115 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20218 DF PROTO=TCP SPT=55116 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20227 DF PROTO=TCP SPT=55119 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20229 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20230 DF PROTO=TCP SPT=55117 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20232 DF PROTO=TCP SPT=55120 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20234 DF PROTO=TCP SPT=55099 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20235 DF PROTO=TCP SPT=55103 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20236 DF PROTO=TCP SPT=55104 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20237 DF PROTO=TCP SPT=55093 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20238 DF PROTO=TCP SPT=55119 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20239 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20240 DF PROTO=TCP SPT=55115 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20241 DF PROTO=TCP SPT=55116 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20242 DF PROTO=TCP SPT=55117 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20243 DF PROTO=TCP SPT=55101 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20244 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20245 DF PROTO=TCP SPT=55119 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20246 DF PROTO=TCP SPT=55103 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20247 DF PROTO=TCP SPT=55104 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20248 DF PROTO=TCP SPT=55115 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20249 DF PROTO=TCP SPT=55116 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20250 DF PROTO=TCP SPT=55117 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20251 DF PROTO=TCP SPT=55107 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20252 DF PROTO=TCP SPT=55108 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20253 DF PROTO=TCP SPT=55095 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20254 DF PROTO=TCP SPT=55109 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20255 DF PROTO=TCP SPT=55113 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20256 DF PROTO=TCP SPT=55119 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420451.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20258 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420451.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20259 DF PROTO=TCP SPT=55103 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420451.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20260 DF PROTO=TCP SPT=55104 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20261 DF PROTO=TCP SPT=55115 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20262 DF PROTO=TCP SPT=55116 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.220000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9347 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20263 DF PROTO=TCP SPT=55117 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20264 DF PROTO=TCP SPT=55098 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20265 DF PROTO=TCP SPT=55097 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20266 DF PROTO=TCP SPT=55119 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.750000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20267 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:01:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420281.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=44977 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sat Jan 01 00:00:09 2011 (GMT +0000): [RV180W] [IKE] INFO:  IKE started
Sat Jan 01 01:02:49 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:02:49 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Jan 01 01:04:50 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Sat Jan 01 01:04:50 2011 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:04:50 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Sat Jan 01 01:04:50 2011 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:04:51 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:04:51 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Wed Apr 08 15:46:36 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:47:45 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:47:46 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:47:48 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:47:52 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:49:37 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:49:39 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:49:41 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:49:45 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Thu Apr 09 10:50:36 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:51:45 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:51:46 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:51:49 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:51:53 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:53:38 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:53:40 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:53:43 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:53:48 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Fri Apr 10 07:58:49 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 07:58:50 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:00:10 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:00:11 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:00:13 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:00:18 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:02:15 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:02:16 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:02:19 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:02:24 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Mon Apr 13 07:36:13 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 151.22.37.140[24050].
Mon Apr 13 07:36:13 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 151.22.37.140[24050]
Mon Apr 13 07:36:48 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:36:50 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:36:52 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:36:56 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:37:04 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:37:20 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:37:36 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Tue Apr 14 06:03:56 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 88.16.132.236[500].
Tue Apr 14 06:06:59 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 88.16.132.236[500].
Tue Apr 14 06:07:01 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 88.16.132.236[500].
Tue Apr 14 06:07:03 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 88.16.132.236[500].
Tue Apr 14 06:07:07 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 88.16.132.236[500].
Tue Apr 14 06:45:33 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:50:32 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:50:34 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:50:36 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:50:40 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:52:32 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:52:33 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:52:35 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:52:40 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Wed Apr 15 07:40:38 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 151.22.37.140[36324].
Wed Apr 15 07:40:38 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 151.22.37.140[36324]
Wed Apr 15 17:13:47 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 71.6.135.131[1659]
Fri Apr 17 02:43:13 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 188.138.9.50[1659]
Fri Apr 17 13:12:18 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 85.25.103.50[60105]
Fri Apr 17 23:13:12 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Fri Apr 17 23:13:12 2015 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Fri Apr 17 23:13:12 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Fri Apr 17 23:13:12 2015 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Fri Apr 17 23:13:13 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Fri Apr 17 23:13:13 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Fri Apr 17 23:13:26 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Fri Apr 17 23:13:26 2015 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Fri Apr 17 23:13:26 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Fri Apr 17 23:13:26 2015 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Fri Apr 17 23:13:27 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Fri Apr 17 23:13:27 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Apr 18 01:27:44 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 67.227.252.62[39123]
Contributor
Have you tried my suggestion
Have you tried my suggestion to unplug everything from the LAN to see if the helps narrow down the issue/reduce the number of messages?
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
Highlighted
Hi SamirThe bug was reported
Hi Samir
The bug was reported under CSCuo58708 but still occurs under version 1.0.4.14
Unplugging everything from the router didn't help btw.
Contributor
Does this happen with no lan
Does this happen with no lan clients plugged in?  If so, something is up with the rv180 and the wan.
If not, plug them back in one at a time until you see the flood of messages.  Once you do, you've identified the lan client that's causing the problem.
