RV180 : NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1
Johannes Kingma
On the RV180W a nonstop stream of reports is logged. Also wan access is sluggish or not reponding.
Our LAN is 172.16.0.0/23.
Example:
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=188.40.60.242 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=63897 DF PROTO=TCP SPT=9001 DPT=39296 WINDOW=388 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=69.164.195.240 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=39497 DF PROTO=TCP SPT=9001 DPT=60289 WINDOW=355 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=69.164.195.240 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=39498 DF PROTO=TCP SPT=9001 DPT=60289 WINDOW=355 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=167.114.3.144 LEN=800 TOS=0x00 PREC=0x00 TTL=63 ID=35201 DF PROTO=TCP SPT=9001 DPT=42634 WINDOW=225 RES=0x00 ACK PSH URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.720000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=168.235.154.96 DST=85.0.87.148 LEN=178 TOS=0x00 PREC=0x00 TTL=51 ID=33841 DF PROTO=TCP SPT=47099 DPT=9001 WINDOW=240 RES=0x00 ACK PSH URGP=0
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1983.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=69.164.195.240 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=39499 DF PROTO=TCP SPT=9001 DPT=60289 WINDOW=355 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1984.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=217.25.221.57 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=20668 DF PROTO=TCP SPT=9001 DPT=57548 WINDOW=351 RES=0x00 ACK URGP=0 MARK=0x1
Oct 12 14:13:51 saturn KERNEL [Kernel] [ 1984.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=69.164.195.240 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=39500 DF PROTO=TCP SPT=9001 DPT=60289 WINDOW=355 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1984.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=88.198.219.54 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=12286 DF PROTO=TCP SPT=9001 DPT=54901 WINDOW=363 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1985.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=74.120.12.135 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=1485 DF PROTO=TCP SPT=9001 DPT=45291 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1985.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=5.149.255.131 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=47050 DF PROTO=TCP SPT=9001 DPT=49043 WINDOW=225 RES=0x00 ACK URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1985.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=66.175.221.24 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=38715 DF PROTO=TCP SPT=9001 DPT=41324 WINDOW=225 RES=0x00 ACK URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1985.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=5.149.255.131 LEN=800 TOS=0x00 PREC=0x00 TTL=63 ID=47051 DF PROTO=TCP SPT=9001 DPT=49043 WINDOW=225 RES=0x00 ACK PSH URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1986.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=24.128.235.42 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65352 DF PROTO=TCP SPT=9001 DPT=56022 WINDOW=352 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1986.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=69.164.195.240 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=39501 DF PROTO=TCP SPT=9001 DPT=60289 WINDOW=355 RES=0x00 ACK FIN URGP=0 MARK=0x1
Oct 12 14:13:52 saturn KERNEL [Kernel] [ 1986.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=172.16.0.8 DST=24.128.235.42 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65353 DF PROTO=TCP SPT=9001 DPT=56022 WINDOW=352 RES=0x00 ACK FIN URGP=0 MARK=0x1
6 Replies 6
Ismael Arroyo
Johanness,
I have noticed the /23 subnet. So how many user or devices are getting ip addresses and passing traffic on this router?
I fail to understand what a subnet mask has to do with the root cause of the problem.,
Dear Ismael.
The current layout with the same router is a 192.168.111.0/27 network:
Sun Apr 19 15:01:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420281.290000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6205 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:01:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420281.340000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18271 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:01:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420281.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18272 DF PROTO=TCP SPT=54924 DPT=443 WI
Sun Apr 19 15:01:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420281.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18273 DF PROTO=TCP SPT=54852 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420282.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18281 DF PROTO=TCP SPT=54895 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420282.720000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=41998 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420282.880000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6206 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420282.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.15 DST=195.143.229.67 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=14242 DF PROTO=TCP SPT=54747 DPT=443 WINDOW=0 RES=0x00 ACK RST URGP=0 MARK=0x1
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.000000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=41999 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.100000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44491 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.340000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18283 DF PROTO=TCP SPT=54861 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18284 DF PROTO=TCP SPT=54863 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18285 DF PROTO=TCP SPT=54862 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.540000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42000 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420283.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=45284 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18292 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18298 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.330000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44492 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18300 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.630000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42001 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18301 DF PROTO=TCP SPT=54924 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420284.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18302 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420285.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18307 DF PROTO=TCP SPT=54918 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420285.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18308 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420285.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18309 DF PROTO=TCP SPT=54905 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420286.050000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6207 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420286.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18310 DF PROTO=TCP SPT=54867 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420286.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18311 DF PROTO=TCP SPT=54920 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420286.800000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44493 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420286.820000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42002 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18323 DF PROTO=TCP SPT=54929 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18330 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18335 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18337 DF PROTO=TCP SPT=54870 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18339 DF PROTO=TCP SPT=54931 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18341 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18342 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420287.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18343 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420288.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18344 DF PROTO=TCP SPT=54922 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420288.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18345 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420289.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18346 DF PROTO=TCP SPT=54909 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420289.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=45427 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.190000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=81.30.152.25 DST=178.199.245.179 LEN=64 TOS=0x00 PREC=0x00 TTL=52 ID=50902 DF PROTO=TCP SPT=33624 DPT=9001 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18354 DF PROTO=TCP SPT=54873 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18356 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18361 DF PROTO=TCP SPT=54875 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18362 DF PROTO=TCP SPT=54874 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18364 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18365 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18366 DF PROTO=TCP SPT=54879 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18367 DF PROTO=TCP SPT=54880 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18368 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:23 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420290.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18369 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420291.180000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42003 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420291.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18371 DF PROTO=TCP SPT=54924 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420291.750000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44494 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420291.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18372 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420292.400000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6208 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420292.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18373 DF PROTO=TCP SPT=54913 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420292.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18385 DF PROTO=TCP SPT=54933 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420292.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18392 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420292.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18398 DF PROTO=TCP SPT=54935 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420293.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18401 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420293.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18402 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420293.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18403 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420293.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18404 DF PROTO=TCP SPT=54883 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420293.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18405 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420294.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18406 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420294.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18407 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420295.210000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=81.30.152.25 DST=178.199.245.179 LEN=178 TOS=0x00 PREC=0x00 TTL=52 ID=50903 DF PROTO=TCP SPT=33624 DPT=9001 W
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420295.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18412 DF PROTO=TCP SPT=54916 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420295.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18419 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18426 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18427 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.360000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=212.51.159.55 DST=178.199.245.179 LEN=178 TOS=0x00 PREC=0x00 TTL=48 ID=27919 DF PROTO=TCP SPT=36543 DPT=9001
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18428 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18429 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420296.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18430 DF PROTO=TCP SPT=54885 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420297.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18432 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420297.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18433 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.050000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=83.168.200.204 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=48552 DF PROTO=TCP SPT=9001 DPT=39473 WINDOW=368 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.280000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.25.148.130 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=12313 DF PROTO=TCP SPT=53130 DPT=9001 W
Sun Apr 19 15:01:29 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18445 DF PROTO=TCP SPT=54938 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18453 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18457 DF PROTO=TCP SPT=54918 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18459 DF PROTO=TCP SPT=54940 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18461 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420298.940000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=5.135.148.171 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=51 ID=0 DF PROTO=TCP SPT=9001 DPT=39202 WINDO
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420299.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18463 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420299.270000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18464 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420299.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18465 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420299.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=48377 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420299.920000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42004 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420300.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18466 DF PROTO=TCP SPT=54920 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420300.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18467 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420300.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18468 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420300.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18469 DF PROTO=TCP SPT=54887 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420301.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18478 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420301.640000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44495 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420301.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18484 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420301.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18485 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420301.960000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18486 DF PROTO=TCP SPT=54922 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420302.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18487 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420302.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18488 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420302.560000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.241.222.98 DST=178.199.245.179 LEN=64 TOS=0x00 PREC=0x00 TTL=51 ID=53045 DF PROTO=TCP SPT=443 DPT=43894 WI
Sun Apr 19 15:01:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18489 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14195 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14196 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18491 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14197 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420303.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18492 DF PROTO=TCP SPT=54889 DPT=443 WI
Sun Apr 19 15:01:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14198 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18503 DF PROTO=TCP SPT=54942 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18510 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18516 DF PROTO=TCP SPT=54944 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18518 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18519 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18520 DF PROTO=TCP SPT=54924 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420304.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18521 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420305.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14199 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420305.100000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6209 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420305.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18523 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420305.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18524 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420306.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18525 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420306.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18526 DF PROTO=TCP SPT=54891 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14200 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.260000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18537 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18544 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18545 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18546 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420307.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18547 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:40 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420308.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18548 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:41 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420308.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18549 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:41 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420309.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18551 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:41 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420309.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18552 DF PROTO=TCP SPT=54895 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420309.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18564 DF PROTO=TCP SPT=54946 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18572 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18577 DF PROTO=TCP SPT=54948 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18579 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18580 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18581 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18582 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18583 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420310.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14201 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420311.200000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38492 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420311.420000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38493 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420311.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18585 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420311.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18586 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420311.880000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38494 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8231 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8232 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8233 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18587 DF PROTO=TCP SPT=54905 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.790000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38495 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420312.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18594 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420313.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8234 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420313.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18602 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420313.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18603 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420313.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18604 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420313.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18605 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18606 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.140000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8235 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18607 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.620000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38496 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18608 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420314.830000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1564 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.080000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1565 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.330000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1566 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18621 DF PROTO=TCP SPT=54950 DPT=443 WI
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18628 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.760000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18634 DF PROTO=TCP SPT=54952 DPT=443 WI
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.830000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1567 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18636 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420315.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18637 DF PROTO=TCP SPT=54909 DPT=443 WI
Sun Apr 19 15:01:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18638 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8236 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18639 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.440000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2740 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18640 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.690000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2741 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.850000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1568 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420316.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18641 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420317.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18645 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420317.180000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2742 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420317.390000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.223.11.56 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=45 ID=42005 DF PROTO=TCP SPT=51678 DPT=9001 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420317.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18647 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.180000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2743 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.280000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38497 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18654 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14202 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18661 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18662 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420318.870000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1569 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420319.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18664 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420319.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18665 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420319.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18666 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420319.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18667 DF PROTO=TCP SPT=54913 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420320.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18668 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420320.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2744 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420320.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8237 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:52 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420320.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18669 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:01:53 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420320.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=50182 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.260000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18682 DF PROTO=TCP SPT=54955 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18692 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.410000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=54.69.107.96 DST=178.199.245.179 LEN=89 TOS=0x00 PREC=0x00 TTL=42 ID=44496 DF PROTO=TCP SPT=443 DPT=45549 WIN
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18695 DF PROTO=TCP SPT=54957 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.540000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=212.51.159.55 DST=178.199.245.179 LEN=64 TOS=0x00 PREC=0x00 TTL=48 ID=27920 DF PROTO=TCP SPT=36543 DPT=9001 W
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18697 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420321.760000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18698 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18699 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18700 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18701 DF PROTO=TCP SPT=54916 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18702 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18703 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420322.910000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1570 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420323.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18705 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420324.140000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2745 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420324.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18713 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420324.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18719 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420324.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18720 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420324.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18721 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18722 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.310000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18724 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.560000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.241.222.98 DST=178.199.245.179 LEN=798 TOS=0x00 PREC=0x00 TTL=51 ID=53046 DF PROTO=TCP SPT=443 DPT=43894 W
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.600000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38498 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18725 DF PROTO=TCP SPT=54918 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420325.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18726 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420326.180000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18727 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420326.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18728 DF PROTO=TCP SPT=54920 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420326.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18740 DF PROTO=TCP SPT=54959 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18751 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18754 DF PROTO=TCP SPT=54963 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65080 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18760 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65081 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:01:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18762 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.630000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65082 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18763 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420327.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18764 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65083 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18765 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8238 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18766 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18767 DF PROTO=TCP SPT=54922 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420328.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18768 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420329.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65084 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18776 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18783 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18784 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.510000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6210 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18785 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18786 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18787 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420330.990000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1571 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420331.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=83.168.200.204 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=48553 DF PROTO=TCP SPT=9001 DPT=39473 WINDOW=368 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420331.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65085 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420331.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18789 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420331.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18790 DF PROTO=TCP SPT=54924 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420331.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18791 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420332.100000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2746 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420332.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18803 DF PROTO=TCP SPT=54966 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420332.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18810 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420332.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18816 DF PROTO=TCP SPT=54968 DPT=443 WI
Sun Apr 19 15:02:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420333.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18818 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420333.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18819 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420333.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18821 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420333.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18822 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420333.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18823 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.150000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2426 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18825 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14203 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.390000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2427 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18826 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.630000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2428 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420334.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18827 DF PROTO=TCP SPT=54926 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420335.120000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2429 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420335.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65086 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420335.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18835 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420335.960000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18842 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420335.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18843 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420336.090000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2430 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420336.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18844 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420336.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18845 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420336.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18846 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420337.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18850 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420337.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18853 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420337.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18854 DF PROTO=TCP SPT=54928 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.050000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2431 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18867 DF PROTO=TCP SPT=54970 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18877 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18880 DF PROTO=TCP SPT=54973 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18882 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420338.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18883 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420339.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18885 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420339.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18887 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420339.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18888 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420339.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18889 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420340.220000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38499 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420340.270000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18890 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420340.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18891 DF PROTO=TCP SPT=54930 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420341.480000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18899 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420341.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18906 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420341.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18907 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420341.950000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2432 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420342.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18908 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420342.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18909 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420342.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18910 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420342.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18911 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420343.270000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18913 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420343.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65087 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420343.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18914 DF PROTO=TCP SPT=54932 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18926 DF PROTO=TCP SPT=54975 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18934 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18939 DF PROTO=TCP SPT=54977 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18941 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8239 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:15 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.630000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18942 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18943 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420344.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18944 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420345.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18946 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420345.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18947 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420346.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18948 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:20 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420346.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18949 DF PROTO=TCP SPT=54934 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.150000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=148.251.69.102 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=1572 DF PROTO=TCP SPT=37158 DPT=9001 W
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18960 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18967 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18968 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18969 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420347.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18970 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420348.020000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2747 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420348.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18971 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420348.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18972 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.000000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18973 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18975 DF PROTO=TCP SPT=54937 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.770000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2433 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18987 DF PROTO=TCP SPT=54979 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=18996 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420349.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19000 DF PROTO=TCP SPT=54981 DPT=443 WI
Sun Apr 19 15:02:21 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420350.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19002 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420350.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19003 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420350.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19004 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420350.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19005 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420351.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19006 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420351.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19008 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420351.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19009 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420352.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19010 DF PROTO=TCP SPT=54939 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420352.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19017 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420353.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19025 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420353.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19026 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420353.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19027 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420353.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19028 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420353.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19029 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420354.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19030 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420354.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19031 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420355.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19033 DF PROTO=TCP SPT=54941 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420355.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19045 DF PROTO=TCP SPT=54983 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420355.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19053 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420355.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19058 DF PROTO=TCP SPT=54985 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420355.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19060 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420356.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19061 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420356.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19062 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420356.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19063 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420356.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19064 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420357.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19069 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420357.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19070 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420357.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19071 DF PROTO=TCP SPT=54943 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420358.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19079 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420358.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19085 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420358.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19086 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420359.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19088 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420359.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19089 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420359.480000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19090 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420359.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=176.10.99.207 LEN=178 TOS=0x00 PREC=0x00 TTL=63 ID=52591 DF PROTO=TCP SPT=48882 DPT=1414 WINDOW=279 RES=0x00 ACK PSH URGP=0 MARK=0x1
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420359.740000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=5.135.148.171 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=51 ID=0 DF PROTO=TCP SPT=9001 DPT=39202 WINDO
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420360.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19091 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420360.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19092 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420360.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=65088 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=439 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420360.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19093 DF PROTO=TCP SPT=54945 DPT=443 WI
Sun Apr 19 15:02:32 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420361.340000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19106 DF PROTO=TCP SPT=54988 DPT=443 WI
Sun Apr 19 15:02:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420361.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19113 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420361.480000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19119 DF PROTO=TCP SPT=54990 DPT=443 WI
Sun Apr 19 15:02:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420361.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19121 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420361.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19122 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420362.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19123 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420362.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19124 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420362.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19125 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420362.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=52805 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420362.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19126 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420363.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60641 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420363.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19128 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420363.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60642 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420363.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19129 DF PROTO=TCP SPT=54947 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420363.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60643 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58358 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60644 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.400000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58359 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19136 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19143 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19144 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420364.900000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58360 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19145 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.140000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19150 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19151 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60645 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.390000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2434 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=85.25.148.130 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14204 DF PROTO=TCP SPT=9001 DPT=53130 WINDOW=2284 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.890000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58361 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420365.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19152 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420366.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19153 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420366.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19154 DF PROTO=TCP SPT=54949 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8714 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.140000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19167 DF PROTO=TCP SPT=54992 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.220000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19174 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19180 DF PROTO=TCP SPT=54994 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8715 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19182 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60646 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:39 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19183 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8716 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19184 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.880000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58362 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420367.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19185 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420368.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8717 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420368.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19186 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420368.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19187 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420368.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19188 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8718 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.150000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34894 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19190 DF PROTO=TCP SPT=54951 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.430000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34895 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.440000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=195.154.81.227 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=38500 DF PROTO=TCP SPT=52786 DPT=9001
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420369.940000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34896 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19197 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19204 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19205 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19206 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19207 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420370.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19208 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.010000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34897 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8719 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.360000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=204.9.55.71 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=47 ID=5759 DF PROTO=TCP SPT=50620 DPT=9001 WIND
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=176.10.99.207 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=52592 DF PROTO=TCP SPT=48882 DPT=1414 WINDOW=279 RES=0x00 ACK URGP=0 MARK=0x1
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19210 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.850000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58363 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60647 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420371.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19211 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420372.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19212 DF PROTO=TCP SPT=54954 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420372.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19223 DF PROTO=TCP SPT=54996 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420372.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19233 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420372.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19236 DF PROTO=TCP SPT=54998 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.120000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34898 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19242 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19243 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19244 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19245 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420373.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19246 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420374.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19247 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420374.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19248 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420374.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19249 DF PROTO=TCP SPT=54956 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420375.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8720 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=1028 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420375.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22186 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420375.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22187 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420375.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22188 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420375.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19257 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19264 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22189 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19265 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19266 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:50 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19267 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420376.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19268 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=148.251.69.102 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=8240 DF PROTO=TCP SPT=9001 DPT=37158 WINDOW=394 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22190 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.360000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34899 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19270 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=19708 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19271 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.750000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=19765 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420377.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19272 DF PROTO=TCP SPT=54958 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420378.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=19798 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420378.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19284 DF PROTO=TCP SPT=55000 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420378.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19291 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420378.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19297 DF PROTO=TCP SPT=55003 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420378.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19299 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19300 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22191 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=20000 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19302 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19303 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19304 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.810000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58364 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:02:51 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420379.820000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=85.10.210.199 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=2748 DF PROTO=TCP SPT=9001 DPT=34550 WI
Sun Apr 19 15:02:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420380.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19305 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420380.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19306 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:02:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420380.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19307 DF PROTO=TCP SPT=54961 DPT=443 WI
Sun Apr 19 15:02:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420380.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60648 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420381.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=20324 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420381.260000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=45.63.84.217 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=6211 DF PROTO=TCP SPT=56972 DPT=9001 WIN
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420381.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19316 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420381.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19322 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420381.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19323 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420382.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19324 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420382.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19325 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420382.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19326 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22192 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54042 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19331 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19332 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.500000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54043 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420383.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19333 DF PROTO=TCP SPT=54965 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.170000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54044 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19344 DF PROTO=TCP SPT=55005 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19354 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19357 DF PROTO=TCP SPT=55007 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19359 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420384.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19360 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19361 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21355 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19363 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19364 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.510000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54045 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.820000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34900 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:02:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420385.960000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19365 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:02:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420386.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19366 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420386.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19367 DF PROTO=TCP SPT=54967 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420387.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19375 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420387.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19382 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420387.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19383 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420388.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19384 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420388.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19385 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420388.200000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54046 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420388.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19386 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420388.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19387 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420389.180000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19389 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420389.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19390 DF PROTO=TCP SPT=54969 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19402 DF PROTO=TCP SPT=55009 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19412 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19417 DF PROTO=TCP SPT=55011 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19419 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19420 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420390.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19421 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420391.000000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19422 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420391.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19423 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420391.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22193 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:03:03 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420391.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21190 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420391.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19426 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420392.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19428 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:03:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420392.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19429 DF PROTO=TCP SPT=54972 DPT=443 WI
Sun Apr 19 15:03:04 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420392.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21251 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420392.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21377 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=22418 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19440 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19447 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.580000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54047 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19448 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21478 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420393.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19449 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420394.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19450 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420394.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19451 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420394.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19452 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420394.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19453 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420395.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19454 DF PROTO=TCP SPT=54974 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420395.710000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58365 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420395.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21760 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.260000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19467 DF PROTO=TCP SPT=55014 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.340000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19477 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:09 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19480 DF PROTO=TCP SPT=55016 DPT=443 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19482 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19483 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.650000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=37.187.130.68 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=2435 DF PROTO=TCP SPT=53251 DPT=9001 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19484 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19485 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:03:10 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420396.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19486 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:11 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420397.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19488 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:03:11 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420397.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19489 DF PROTO=TCP SPT=54976 DPT=443 WI
Sun Apr 19 15:03:11 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420397.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19490 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:11 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420398.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60649 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420399.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19498 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420399.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19505 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420399.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19506 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420399.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19507 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420399.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19508 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19509 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.100000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31889 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=21764 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.340000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31890 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.590000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31891 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.750000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19510 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.760000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19511 DF PROTO=TCP SPT=54978 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420400.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19512 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420401.090000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31892 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:16 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.080000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31893 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.260000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19525 DF PROTO=TCP SPT=55019 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19535 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19538 DF PROTO=TCP SPT=55022 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19540 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19541 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19544 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:03:17 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.800000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34901 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420402.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19546 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19547 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19553 DF PROTO=TCP SPT=54980 DPT=443 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19554 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.660000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=58 ID=55162 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.660000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55163 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.660000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=783 TOS=0x00 PREC=0x00 TTL=58 ID=55164 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.700000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=783 TOS=0x00 PREC=0x00 TTL=58 ID=55165 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19556 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.920000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55166 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420403.960000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55167 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420404.070000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31894 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420404.340000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54048 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420404.350000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55168 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420404.560000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55169 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420405.230000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55170 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:19 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420405.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19569 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:03:19 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420405.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19572 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420405.760000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55171 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420405.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19575 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.180000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19583 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19589 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:24 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19590 DF PROTO=TCP SPT=54982 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19591 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19592 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.960000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55172 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420406.990000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55173 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420407.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22194 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420407.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19594 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420408.040000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31895 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420408.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55174 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420408.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19595 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420408.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19596 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:25 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420408.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=22797 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=24434 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19608 DF PROTO=TCP SPT=55047 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.130000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=212.51.159.55 DST=178.199.245.179 LEN=178 TOS=0x00 PREC=0x00 TTL=48 ID=27921 DF PROTO=TCP SPT=36543 DPT=9001
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19616 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.270000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19622 DF PROTO=TCP SPT=55049 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19624 DF PROTO=TCP SPT=54984 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19625 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19626 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19627 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:26 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420409.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19628 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420410.500000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55175 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420410.560000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55176 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420410.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19629 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420411.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19631 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420412.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19632 DF PROTO=TCP SPT=54987 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420412.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19633 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420412.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19634 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420412.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19635 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420413.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19650 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420413.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19653 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420413.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19654 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:27 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420414.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19657 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420414.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19658 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420414.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19659 DF PROTO=TCP SPT=54989 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420415.360000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=55177 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420415.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19661 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420415.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19662 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420415.990000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31896 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19674 DF PROTO=TCP SPT=55051 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19683 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=38.229.70.53 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=55 ID=51824 DF PROTO=TCP SPT=36160 DPT=9001 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19687 DF PROTO=TCP SPT=55065 DPT=443 WI
Sun Apr 19 15:03:33 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.340000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19689 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19690 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420416.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19691 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420417.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19692 DF PROTO=TCP SPT=55010 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420417.530000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55178 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420417.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19694 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420417.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19695 DF PROTO=TCP SPT=54991 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420418.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19704 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420418.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19707 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19717 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19718 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19719 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19723 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:34 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19730 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19732 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19740 DF PROTO=TCP SPT=55072 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19742 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420419.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19743 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19744 DF PROTO=TCP SPT=55013 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19745 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9339 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:35 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19746 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19747 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.410000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9340 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.660000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9341 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420420.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19748 DF PROTO=TCP SPT=54993 DPT=443 WI
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9342 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:36 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.220000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=25553 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:37 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19750 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:37 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19751 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:37 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.490000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=15174 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:37 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19752 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:37 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420421.830000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=282 DF PROTO=TCP SPT=43826 DPT=9001 WIN
Sun Apr 19 15:03:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9343 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.280000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=82.239.201.196 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=112 ID=6846 PROTO=TCP SPT=55256 DPT=9030 WIN
Sun Apr 19 15:03:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.280000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=56649 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:38 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19753 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.880000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.241.222.98 DST=178.199.245.179 LEN=64 TOS=0x00 PREC=0x00 TTL=51 ID=53047 DF PROTO=TCP SPT=443 DPT=43894 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19781 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19782 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19783 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420422.980000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=18916 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420423.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19784 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420423.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19789 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420423.750000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19790 DF PROTO=TCP SPT=54995 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420424.170000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9344 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420424.170000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=28173 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420424.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19791 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420424.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19800 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:43 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420424.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19803 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420425.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19805 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:44 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420425.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19806 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420425.530000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=1027 DF PROTO=TCP SPT=43826 DPT=9001 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420425.840000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=149.9.0.59 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=54049 DF PROTO=TCP SPT=52559 DPT=9001 WIND
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420425.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19815 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.060000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19824 DF PROTO=TCP SPT=55018 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19827 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19832 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19835 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19836 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:45 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19837 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19838 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19839 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:46 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19841 DF PROTO=TCP SPT=55080 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=80.73.242.142 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=27703 DF PROTO=TCP SPT=36617 DPT=443 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19843 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19844 DF PROTO=TCP SPT=54997 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19845 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420426.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19846 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420427.520000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.192.171 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=58366 DF PROTO=TCP SPT=49604 DPT=9001 W
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420427.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19848 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420427.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19849 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420427.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19850 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420428.040000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=39467 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420428.180000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9345 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420428.750000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.73.242.142 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=44 ID=24684 DF PROTO=TCP SPT=443 DPT=36617 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.050000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19851 DF PROTO=TCP SPT=55021 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19859 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19860 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19866 DF PROTO=TCP SPT=55079 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19868 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.310000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19875 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:47 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19880 DF PROTO=TCP SPT=55082 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19882 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19883 DF PROTO=TCP SPT=54999 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19884 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420429.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19885 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420430.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19886 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420431.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19888 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420431.580000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=1500 TOS=0x00 PREC=0x00 TTL=58 ID=55180 DF PROTO=TCP SPT=443 DPT=55027
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420431.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19889 DF PROTO=TCP SPT=55067 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420431.880000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=213.239.217.18 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=48 ID=31897 DF PROTO=TCP SPT=43724 DPT=9001
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19890 DF PROTO=TCP SPT=55002 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19891 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19892 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:03:48 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19893 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:03:53 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19894 DF PROTO=TCP SPT=55045 DPT=443 WI
Sun Apr 19 15:03:53 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420432.850000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=64619 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:03:53 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19895 DF PROTO=TCP SPT=55070 DPT=443 WI
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19896 DF PROTO=TCP SPT=55069 DPT=443 WI
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19907 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=82.223.11.56 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=60650 DF PROTO=TCP SPT=9001 DPT=51678 WINDOW=572 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19914 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=176.10.99.207 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=52594 DF PROTO=TCP SPT=48882 DPT=1414 WINDOW=279 RES=0x00 ACK URGP=0 MARK=0x1
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.660000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=104.66.163.151 DST=178.199.245.179 LEN=40 TOS=0x00 PREC=0x00 TTL=58 ID=55181 DF PROTO=TCP SPT=443 DPT=55027 W
Sun Apr 19 15:03:54 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420433.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19915 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:03:55 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420434.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19916 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:03:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420435.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19918 DF PROTO=TCP SPT=55004 DPT=443 WI
Sun Apr 19 15:03:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420435.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19919 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:03:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420435.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19920 DF PROTO=TCP SPT=55048 DPT=443 WI
Sun Apr 19 15:03:56 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420435.960000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19921 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:03:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.200000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9346 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:03:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19933 DF PROTO=TCP SPT=55085 DPT=443 WI
Sun Apr 19 15:03:57 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19940 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:03:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19944 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:03:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19947 DF PROTO=TCP SPT=55088 DPT=443 WI
Sun Apr 19 15:03:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19949 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:03:58 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.700000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=31.51.138.200 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=46 ID=34902 DF PROTO=TCP SPT=3854 DPT=9001 WI
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420436.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19950 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420437.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19952 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420437.960000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19953 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420438.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19954 DF PROTO=TCP SPT=55006 DPT=443 WI
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=37.187.109.58 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22195 DF PROTO=TCP SPT=9001 DPT=51449 WINDOW=453 RES=0x00 ACK FIN URGP=0 MARK=0x1
Sun Apr 19 15:03:59 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.310000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19956 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.310000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19957 DF PROTO=TCP SPT=55077 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19958 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19959 DF PROTO=TCP SPT=55084 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420439.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19960 DF PROTO=TCP SPT=55050 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420440.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19967 DF PROTO=TCP SPT=55090 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420440.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19974 DF PROTO=TCP SPT=55090 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420440.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19975 DF PROTO=TCP SPT=55090 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420440.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=88.198.100.230 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=30729 DF PROTO=TCP SPT=9001 DPT=47799 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420441.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19976 DF PROTO=TCP SPT=55008 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420441.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19979 DF PROTO=TCP SPT=55090 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420441.650000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=212.51.159.55 DST=178.199.245.179 LEN=64 TOS=0x00 PREC=0x00 TTL=48 ID=27922 DF PROTO=TCP SPT=36543 DPT=9001 W
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.270000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=80.237.226.75 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=51 ID=42157 DF PROTO=TCP SPT=43826 DPT=9001 W
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19980 DF PROTO=TCP SPT=55081 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19981 DF PROTO=TCP SPT=55064 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19982 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19992 DF PROTO=TCP SPT=55091 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420442.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20002 DF PROTO=TCP SPT=55093 DPT=443 WI
Sun Apr 19 15:04:00 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420443.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20005 DF PROTO=TCP SPT=55094 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20214 DF PROTO=TCP SPT=55117 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20215 DF PROTO=TCP SPT=55118 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20217 DF PROTO=TCP SPT=55115 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20218 DF PROTO=TCP SPT=55116 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20227 DF PROTO=TCP SPT=55119 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20229 DF PROTO=TCP SPT=55073 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20230 DF PROTO=TCP SPT=55117 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20232 DF PROTO=TCP SPT=55120 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20234 DF PROTO=TCP SPT=55099 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20235 DF PROTO=TCP SPT=55103 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20236 DF PROTO=TCP SPT=55104 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20237 DF PROTO=TCP SPT=55093 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20238 DF PROTO=TCP SPT=55119 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20239 DF PROTO=TCP SPT=55087 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20240 DF PROTO=TCP SPT=55115 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20241 DF PROTO=TCP SPT=55116 DPT=443 WI
Sun Apr 19 15:04:06 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20242 DF PROTO=TCP SPT=55117 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20243 DF PROTO=TCP SPT=55101 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20244 DF PROTO=TCP SPT=55015 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420449.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20245 DF PROTO=TCP SPT=55119 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20246 DF PROTO=TCP SPT=55103 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20247 DF PROTO=TCP SPT=55104 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20248 DF PROTO=TCP SPT=55115 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20249 DF PROTO=TCP SPT=55116 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20250 DF PROTO=TCP SPT=55117 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20251 DF PROTO=TCP SPT=55107 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20252 DF PROTO=TCP SPT=55108 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20253 DF PROTO=TCP SPT=55095 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20254 DF PROTO=TCP SPT=55109 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20255 DF PROTO=TCP SPT=55113 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420450.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20256 DF PROTO=TCP SPT=55119 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420451.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20258 DF PROTO=TCP SPT=55075 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420451.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20259 DF PROTO=TCP SPT=55103 DPT=443 WI
Sun Apr 19 15:04:07 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420451.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20260 DF PROTO=TCP SPT=55104 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20261 DF PROTO=TCP SPT=55115 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20262 DF PROTO=TCP SPT=55116 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.220000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=d8:67:d9:d2:4a:c3 SRC MAC=00:90:d0:63:ff:04 PAYLOAD TYPE=08:00 SRC=176.9.103.8 DST=178.199.245.179 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=9347 DF PROTO=TCP SPT=54285 DPT=9001 WIND
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20263 DF PROTO=TCP SPT=55117 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20264 DF PROTO=TCP SPT=55098 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20265 DF PROTO=TCP SPT=55097 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.470000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20266 DF PROTO=TCP SPT=55119 DPT=443 WI
Sun Apr 19 15:04:08 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420452.750000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=d8:67:d9:d2:4a:c2 SRC MAC=e0:cb:4e:55:32:22 PAYLOAD TYPE=08:00 SRC=192.168.111.15 DST=192.168.111.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=20267 DF PROTO=TCP SPT=55078 DPT=443 WI
Sun Apr 19 15:01:18 2015(GMT+0100) [saturn][Kernel][KERNEL] [1420281.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.111.8 DST=38.229.70.53 LEN=40 TOS=0x00 PREC=0x00 TTL=63 ID=44977 DF PROTO=TCP SPT=9001 DPT=36160 WINDOW=0 RES=0x00 RST URGP=0 MARK=0x1
Sat Jan 01 00:00:09 2011 (GMT +0000): [RV180W] [IKE] INFO:  IKE started
Sat Jan 01 01:02:49 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:02:49 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:03:10 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:04:26 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Jan 01 01:04:50 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Sat Jan 01 01:04:50 2011 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:04:50 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Sat Jan 01 01:04:50 2011 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:04:51 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:04:51 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:05:42 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Sat Jan 01 01:05:52 2011 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Fri Apr 03 06:30:13 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Wed Apr 08 15:46:36 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:47:45 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:47:46 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:47:48 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:47:52 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:49:37 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:49:39 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:49:41 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Wed Apr 08 15:49:45 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 37.24.137.214[500].
Thu Apr 09 10:50:36 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:51:45 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:51:46 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:51:49 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:51:53 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:53:38 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:53:40 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:53:43 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Thu Apr 09 10:53:48 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 14.141.41.214[447]
Fri Apr 10 07:58:49 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 07:58:50 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:00:10 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:00:11 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:00:13 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:00:18 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:02:15 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:02:16 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:02:19 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Fri Apr 10 08:02:24 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 178.135.30.71[49768].
Mon Apr 13 07:36:13 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 151.22.37.140[24050].
Mon Apr 13 07:36:13 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 151.22.37.140[24050]
Mon Apr 13 07:36:48 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:36:50 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:36:52 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:36:56 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:37:04 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:37:20 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Mon Apr 13 07:37:36 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 246 from 151.22.37.140[24050].
Tue Apr 14 06:03:56 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 88.16.132.236[500].
Tue Apr 14 06:06:59 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 88.16.132.236[500].
Tue Apr 14 06:07:01 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 88.16.132.236[500].
Tue Apr 14 06:07:03 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 88.16.132.236[500].
Tue Apr 14 06:07:07 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 88.16.132.236[500].
Tue Apr 14 06:45:33 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:50:32 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:50:34 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:50:36 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:50:40 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:52:32 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:52:33 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:52:35 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Tue Apr 14 06:52:40 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 87.69.222.163[500].
Wed Apr 15 07:40:38 2015 (GMT +0100): [saturn] [IKE] ERROR:  Invalid exchange type 243 from 151.22.37.140[36324].
Wed Apr 15 07:40:38 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 151.22.37.140[36324]
Wed Apr 15 17:13:47 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 71.6.135.131[1659]
Fri Apr 17 02:43:13 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 188.138.9.50[1659]
Fri Apr 17 13:12:18 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 85.25.103.50[60105]
Fri Apr 17 23:13:12 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Fri Apr 17 23:13:12 2015 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Fri Apr 17 23:13:12 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Fri Apr 17 23:13:12 2015 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Fri Apr 17 23:13:13 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Fri Apr 17 23:13:13 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Fri Apr 17 23:13:26 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase2 found for "kingma"
Fri Apr 17 23:13:26 2015 (GMT +0100): [saturn] [IKE] INFO:  IPSec configuration with identifier "kingma" deleted sucessfully
Fri Apr 17 23:13:26 2015 (GMT +0100): [saturn] [IKE] WARNING:  no phase1 found for "kingma"
Fri Apr 17 23:13:26 2015 (GMT +0100): [saturn] [IKE] INFO:  IKE configuration with identifier "kingma" deleted sucessfully
Fri Apr 17 23:13:27 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IPSec configuration with identifier "kingma"
Fri Apr 17 23:13:27 2015 (GMT +0100): [saturn] [IKE] INFO:  Adding IKE configuration with identifier "kingma"
Sat Apr 18 01:27:44 2015 (GMT +0100): [saturn] [IKE] ERROR:  Could not find configuration for 67.227.252.62[39123]
Have you tried my suggestion to unplug everything from the LAN to see if the helps narrow down the issue/reduce the number of messages?
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
Hi Samir
The bug was reported under CSCuo58708 but still occurs under version 1.0.4.14
Unplugging everything from the router didn't help btw.
SamirD
Level 5
Level 5
Does this happen with no lan clients plugged in?  If so, something is up with the rv180 and the wan.
If not, plug them back in one at a time until you see the flood of messages.  Once you do, you've identified the lan client that's causing the problem.
