Hi all,
I have configured a Cisco RV180/RV180W PPPoE profile, as described by the KB (Options: Keep Connected, Auto-negotiate).
After saving the configuration it won't connect automatically to the internet, even if I restart the device.
When I press the connect button, it connect to the internet. After restarting the router it will connect automatically to the internet (as expected).
If I create a config backup and restore it on another device the problem will be the same, I have to press the Connect button to start the automatic dialing... I use the last firmware.
Is there a workaround solution?
Does anyone have the same problem?
Many Thanks
Martin
