Good morning
Hi Bob, thanks for using our forum, my name is Johnnatan and I am part of the Small business Support community. Fist at all I apologize for the issues you are having, in order to help you I was wondering if could you tell us a little more about your problem, for example:
What kind of VPN are you configuring? Are you using IPsec?
What is MTU size of your device for the connections?
Could you share with us some screenshot of your Wifi configuration?
Did you isolate both, vlan and Wifi?
Ensure you are running the firmware 1.0.1.9
Thank you and again I apologize for the issues you are having.
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
“Please rate useful posts so other users can benefit from it”
Greetings,
