RV215w - port forwarding
hajek
Beginner
Beginner
Hello everyone,
I am trying to find out how many addresses can be added to the port forwarding section of the Cisco RV215w .
Does anybody know this by chance? I need a router that is able to port forward at least 50 addresses.
Thank you all in Advance
Tom
Samir Darji
Contributor
Contributor
I don't know if there's any technical information on this, and even if there way, I'm sure it would vary based on the firmware version.  The only thing I can suggest is to try it and report back with your results.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
Glenn Martin
Hi Tom:
The Max on the RV215W is 20 (30 on the RV320/RV325 families). Not sure what your environment is, however have you considered Port Triggering with NAT, this should give you more flexibility.
Let me know if this answers your question or not, and also don't forget to select Correct Answer and rate this answer if it helps.
Glenn
Recognize Your Peers
