Announcement“Cisco Design Thinking Workshop”. Cisco Small Business is excited to invite its Silicon Valley customers to an exclusive interactive one-day session between customers and product Managers.  If you are interested in this exclusive workshop, please fill out the Registration Form. For more information, please check out our FAQ
Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
269
Beginner
rv215w port mirroring not work
I have rv215w router. I have set up port mirroring from source port 1 to destination port 2, and connected my pc to port 2. But on the pc, no port 1's packages came.
I tried two rv215w router, the results were same.
Can some one help on the issue?
Here is the instruction for the port mirroring
Port Mirroring
Step 1. Log in to the web configuration utility, choose Administration > Diagnostics > Port Mirroring. The Port Mirroring page opens:
Step 2. Check the desired Mirror Source port from the available ports. This is the port on which the network port is monitored.
Step 3. Choose the desired port from the Mirror Port drop-down list. This is the port on which the network traffic is analyzed.
Step 4. Click Save.
Everyone's tags (2)
1 REPLY 1
Advocate
Re: rv215w port mirroring not work
Hi @rv215w ,
Theoretically, these should be all the necessary configurations.
Make sure you are using the port of desctino for another type of traffic.
STEP 1 Choose Administration > Diagnostics > Port Mirroring.
STEP 2 In the Mirror Source field, select the ports to mirror.
STEP 3 From the Mirror Port drop-down menu, choose a mirror port. If you use a port for
mirroring, do not use it for any other traffic.
STEP 4 Click Save.
Also, you could tell us what kind of tests you are doing to rule out other options.
