RV215w PPTP with 192.168.1.x subnet
k_anderson
Beginner
Beginner
I have been trying to setup a PPTP VPN with the Cisco RV215w router and have discovered that CISCO won't permit a 192.168.1.x network when a PPTP VPN is setup.   I am well aware that I can't have an identical subnet at the other end, and have made  accommodations for that.  The copy machine people have installed some equipment and I don't have access to those machines to change the subnet on them. Hopefully there is a work around for this!
Dennis Bigelow
Are you on the latest firmware (1.2.0.15)? If not, you are most likely running into bug (CSCuh20473).
This bug does not allow you to add a zero to the local subnet.
I hope this helps.
Chris
Recognize Your Peers
