RV215W problem when change defaault LAN ip address range
ALBI XHAKO
Hello Experts. I have an issue with the brand new Cisco RV215W. When i ping the default LAN ip address (192.168.1.1) of the router RV215 W from my pc i get 1ms. As soon as i change the LAN settings (e.g 192.168.10.1 ) the ping will rise up to 10ms. I dont have any other devices in beetween and i have tried different cables , laptop).
Thanks in advance
5 Replies 5
Yogi-Bear
What's its software version? Lets have a look at the current issues on your version. First thing I would try is to look for existing bugs.
 Thank you for your  reply Bobby.    The firmware is 1.3.0.8
I  have tried many firmware versions, same  result.
My name is Iliya Gatsev from Cisco Technical Support Team.
It will be good to call our support line and open a support case.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
Hello Iliya ,
Thanks for reply. I dont see any support contacts for my country (Albania ,Europe). Iam having problems to create a case. Can you give me an link chat to talk with someone. I dont have much time.
Many thanks
There is no dedicated number for Albania. Please use  +44 2 030 274 627 for other European Countries just to create the support case.
Iliya Gatsev
