2270
Highlighted
Beginner
RV220W Arbitrary Port Forwarding
I have been able to use the IPv4 Firewall rules to do port forwarding for HTTP coming in port 80 since it is one of the listed Services but I don't see how to configure port forwarding for an arbitrary port number. This was obvious with my older WRV200. Is there a way specify an arbitrary port that one would like to have forwarded or is the router limited to the list of Services in the pull down menu?
Brian
1 ACCEPTED SOLUTION
Highlighted
Rising star
Hi Brian,
Thank you for posting. Try Firewall-> Access Control-> Custom Services. Create your new service and you will be able to select it from IPv4 Firewall Rules. This is certainly a big change from our legacy routers. Please let us know if this helps or if you need further assistance.
3 REPLIES 3
Highlighted
Rising star
Hi Brian,
Highlighted
Thanks, thats what I couldn't find. Problem solved.
Thanks again,
Brian
Highlighted
Brian,
Your welcome. Your feedback is appreciated!
