05-16-2011 10:53 AM
I'm relatively new to establishing VPN connections and I'm having one heck of a time getting everything configured.
I'm setting up a RV220W at the office and trying to get VPN steup. I've have gotten Quick VPN connections working using the QuickVPN software. I've given up for now on IPsec VPN connactions and will come back to these later.
What I'd like to get setup is the SSL VPN connections using the Win7 built in VPN client. Is this even possible? I initially tried to connect to the VPN via the SSL Web access but I cannot get the software/divers to install on any of the 3+ Win7 64 bit machines I tried.
So can the SSL VPN on the RV220W be setup to connect to with the Win7 VPN Client using SSTP?
Any links or guidance on how to setup the cerificates on the server and where to install them on the Client PCs? I think this is my major issue right now as the error I get when I try to connect is either: "The certificate's CN name does not match the passed value" (Error Code: 0x800B010F) or " A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider" (Error Code: 0x800B0109). I'm trying to use self signed certifcates and I'm not sure if that is the issue (self signed vs genuine) but I really am not getting anywhere with this.
Also, the VPN does not have a FQDN just a static IP if this matters.
While I'm at it, I'd also gladly take any good links for IPsec on the RV220W but I wont be tackling that until SSL & the certificates are setup.
Justin
05-16-2011 02:03 PM
OK. Sorry to reply to myself but I got a few steps further. I figured I'd post how in case anyone needs to references this in the future or correct something I've done wrong.
These steps got me closer.
Now when I try to connect using the Win7 VPN Client with SSTP I get a new error: Error Description: 0x800704D4: The network connection was aborted by the local system.
Any idea how to resolve this on the RV220W?
- Justin
05-18-2011 07:31 AM
Hi Justin,
Thanks for sharing your findings! However since this question is about a product in the Cisco Small Business / Linksys range, I suggest you move this thread to (or start a new one in) the community, where you will have a better chance of getting expert advice.
best regards,
Herbert
Cisco Moderator
05-20-2011 08:51 PM
I would try to reissue the cert with IP and port # running SSL so when creating the Cert on the ip 10.0.0.20 and you are running the SSL on 5000 (remote mgmt port) type 10.0.0.20:5000
Typically that error occurs when the certificates bound to the HTTPS listener for IPv4 do not match. This also applies if you are using IPv6
09-27-2011 06:20 PM
Hi Justin,
I'm facing similar issues as you are describing above. Did you finally solve it?
I'm trying to set up RV220w working with mac via SSL VPN client Tunnelblick...
Thanks, David
02-02-2012 03:59 AM
I'm trying to set up same thing. Did you find any solution?
02-05-2012 06:01 PM
Hi, no, there is no solution but change device :]]
I didn't solve any of my issues
- SSL VPN for mac 10.7 IS NOT WORKING
- NO IPSEC VPN support for mac
- NO SSL/IPSEC iPhone client
I don't see any reason to use this device any more...
Good luck
