Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
1218
Highlighted
Beginner
RV220W Critical error
I was trying to adjust some parameters on the administrative interface on the Rv220w when I got the message 'A critical error encountered while loading web page'.  At this point the admin web page was 'locked', and I had to close the page and log back in again.  I was trying to adjust the remote logging parameters when this happened.  I checked in the logs, but there was no information about this problem.
I there something that I should do to avoid this problem?
5 REPLIES 5
Highlighted
Rising star
This is a known iss and a workaround is provided in the firmware release note.
A critical error is encountered when attempting to configure settings for remote logging to a syslog server.
Work Around:
Enable email logging on the Administration > Logging >Remote Logging Configuration page.
Note: you do not need a real Email server in the LAN to apply the workaround.
Highlighted
Thanks for the info.  I had a look at the firmware release notes and there are a number of other issues listed there that might be causing problems for me as well.  For some of these issues the listed workarounds are rather impractical and would lead to pooer security, not better (e.g. install Windows XP instead of Windows 7, create root logins on Mac's).  Do you have any estimated date for when these issues will be resolved?
Highlighted
Work Around:
Hmmm, I would indeed hardly call this a workaround, To keep the mails readable most people would probably need to send a mail every half hour, which would fill up a mailbox quite easily...
When will a fix for this be ready?
Highlighted
The issue has been fixed. Please contact the Support Center if you need this fix immediately.
Highlighted
Sorry for the late reply.
To be honest: I don't need the fix immediately, so I'll wait for the official release.
Thanks for the quick reply
