04-15-2011 03:18 PM
Cisco,
Just downloaded this firmware from your site, and it appears to be corrupt....
I am noticing that the saved file size appears to be smaller than previous versions.
Can you please double check and make sure the file being downloaded from your site is the correct?
When I try to install the downloaded firmware, it fails saying the file is corrupt.
04-15-2011 04:26 PM
Hi Jason,
Thank you for posting. The firmware you downloaded is for the RV120W, not the RV220W. Version 1.0.0.26 is the only version available for the RV220W. Version 1.0.1.0 has been removed from the download section due to an issue with PPPoE connections failing.
07-12-2011 08:54 AM
Is the bug fixed now? I can still download the firmware, dated to: march/2011
07-12-2011 09:19 AM
hi
sorry when i check the cisco website for the rv220w firmware there is only
1.0.1.0 and no other (newer) versions.....
...please let me know
