RV220W firmware 1.0.5.8 - QUICK VPN Client No Longer Connects
JPGSTUDIOS
After I updated my RV220W with 1.0.5.8 Firmware, I can no longer get my VPN to work, using the Quick VPN Client.
I was using it just before I updated this firmware.
I do not see any issues that would prevent this connnection.
I don't see any errors about this in the Release Notes.
Anyone else have this issue?
johmuell
We have tested this again in the lab with windows xp, vista, and win7 without issue. After you upgraded the firmware, did you factory default the unit and reconfigure by chance? If you do not want to go that route just yet, had you deleted your qvpn account in the router gui and recreate it and test again?
pren
I had the exact same issue after an upgrade from 1.0.4.17 to 1.0.5.8 and Quick VPN didn't work anymore but also Remote Management using a web browser from the Internet. I solved this by unchecking the setting for Enable Remote Management under Administration\Remote Management and clicked Save at the bottom of the page. I then checked Enable Remote Management again and Save once more and everything started working again.
