09-05-2011 04:07 AM
I've previously upgraded the firmware on our RV220W from 1.0.0.26 to 1.0.1.0 without any problems but all attempts to upgrade to the latest version 1.0.2.4 fails with the following message "Upgrade failed due to invalid/corrupted firmware". The router then automatically reboots with the current firmware.
We've already tried re-downloading and applying the update from several different machines using different operating systems and browsers without success. Has anyone else managed to apply this firmware version successfully? We really need one of the VLAN fixes included in this latest version!
Any suggestions would be much appreciated.
Solved! Go to Solution.
09-05-2011 12:55 PM
have you tried reseting the router back to factory defaults?
coming from 1.0.2.6 requires a factory reset once you have upgraded to 1.0.1.0 so perhaps this still needs a reset?
09-05-2011 12:55 PM
09-06-2011 06:34 AM
Much appreciated!!!
I didn't realise a factory reset is required after each firmware upgrade.
09-06-2011 07:38 AM
it was only required after the first initial firmware afaik
