Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
951
pauljcamacho
Beginner
RV220W fw. 1.0.3.5 Port forwarding with static IP's
I have read every post here about port forwarding on the RV220W and none are clear. here is my scenario.
I have 5 static IP Addresses. I want to use one of the IP addresses to setup remote access using Remote Desktop Connection from outside the office using port address translation. for example i would like to use RDC and a specific port such as 7000 and connect to an internal PC on port 3389. sounds simple. i do this all the time on Cisco ASA's, Netgear, D-link, etc. but for the life of me cannot do it on this cisco firewall. so the port address should look like 25.25.25.25:7000 and connect to 192.168.1.25:3389. i have tried everything based on the posts without luck. Any help will be greatly appreciated.
1 REPLY 1
rmanthey
Enthusiast
Hello Paul,
We would have to see how you have the router configured, Is there any way you could call into the support center at 1866-606-1866 and have a case opened?
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
