Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
1223
Highlighted
Beginner
RV220W - LAN users can not hit services served on WAN
I have Ports open, with DNS named defined for internal services..
When extertnal they work by name just fine, so the firewall's working Ok.
But when on the LAN they fail.
When I look at the port forwarding rules, I see  Outside -> Inside,  but there's no Inside -> Inside..
How can my LAN users use DNS Names/Ports that are on the WAN interface,,.  so when they come between the WAN and LAN their apps continue to work ?
1 ACCEPTED SOLUTION
Highlighted
Hi Aaron
After the upgrade to the new fw i had to remove ALL my Access rules and Custom Services. Then i added them again and all started to work.
Firewall --> Access rules
Firewall --> Advanced settings --> Custom Services
6 REPLIES 6
Highlighted
Frequent Contributor
Aaron,
Their was an open bug for a older firmware with hairpin issues. The fix for that bug was 1.0.1.x , are you on the latest firmware? If you're on the latest firmware and still having problems i would give SBSC @ 1-866-606-1866 a call and open a support case so you can have next available engineer assist with your issues
jasbryan
Highlighted
Yea, Im on 1.0.3.5
I will call Support, Cheers
Highlighted
Beginner
Help
I had this working,  due to the firmware update,  last night I updated to 1.0.4.17 and now the issue's back..
I can not hit DNS names which point back to my external IP.
eg:  use a domain name to address items inside my LAN (port forwarding/etc) is all working.
it seems it's directing it to the firewall login,
Highlighted
So you cannot access services from the LAN. have you tried setting on of the DNS entries to the LAN IP of the Router?
Also try adding the IP/Name of the Service your trying to get too in the HOSTS file of the PC.
Regards Simon
http://www.linksysinfo.org
Regards Simon
Highlighted
Hi Aaron
Highlighted
Hey, that's the issue THANK YOU..
I recreated my rules and it worked (I tried a restore, and that failed)
it sucks that an firmware upgrade blows away your configuration like this
Thanks for your help
