RV220W Login problem
tronsliver
                   I inadvertenly locked myself out of my router (RV220W)  while setting up QuickVPN. I cheked the box to not allow "browsers" to access the router configuration. Very stupid! Anyway is there another way to log into the router other than using typical browsers or do I need to reset?
Roger
Tom Watts
Hello Roger, unfortunately the reset is the only way aside from http or https access.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
