first problem : VPN tunnel was working fine with an rv042, then it stops working.I didn't changed the configuration. i connect another router and the VPN tunnel works right away!
second tunnel : i've update the firmware to the latest version 1.0.3.5 but i had many problem with the interface, specially with the vlan isolation. So i went down to 1.0.1.0
should i do an RMA ?
