RV220W not displaying DHCP lan leased ips
jasonborenstein
RE: RV220W
I have wired and wireless devices picking up DHCP IPs from the RV220W...
When I click on: NETWORKING / LAN / DHCP LEASED CLIENTS (LAN), it always displays 0 assigned IPs. Why?
I can see my connected lan machines/devices via: STATUS / AVAILABLE LAN HOSTS.
Thanks-
Jason
shawnmbrown
I receive the same error. I have updated to the newest firmware as well. I do see the hosts under Available LAN hosts under System status.
...as per Cisco support ticket# 617194663, I was told by the support analyst, that after the firmware upgrade, I should restore factory defaults, and reload my configuration file, which I have done, and still don't see my leased DHCP IP's....
Any other suggestions? Anyone from Cisco?
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center.
First, Thank you for purchasing a Cisco product. I am sorry to here that you are still having the issue. I am going to follow-up with the agent that was working your case and work on determining what is causing your issue.
If you need anything, please let me know. You can reach me at emoyers at cisco . com
Eric Moyers
Cisco Network Support Engineer
1-866-606-1866
jasonborenstein
Cisco support was able to replicate this issue, and its being logged as a bug...
