12-12-2011 05:07 PM
Hi, im going crazy trying to debug this issue..
I have 6 port forwarding rules, they all work except one. (slingbox, etc)
I have a Win7 PC running an HTTP server on Port 8080, firewall is turned off on the Win 7 PC. I have hit and access the service from inside my network.
I have all the rules setup as you would expect, custom service, port forwarding, etc.
Cisco support how can I work with you on debugging this, is there any particular logs I can send
thanks
12-12-2011 05:40 PM
Hi Aaron,
Thank you for posting. Did you create the rule for http 8080 under Port Forwarding or Access Rules? There is a known issue with Port Forwarding and we recommend that all rules be created under Access Rules until the issue is fixed by a firmware update. After the rule is created it will show up under "Port Forwarding". Also, make sure that the rule is configured like the ones that are working.
12-12-2011 08:22 PM
I read that issue, and figured it was the problem, so I already deleted the custom service definition (8080) and the port forwarding and access rules.. then I recreated just using an access rule. -- that's my current configuration
I was on an older firmware and moved to this latest version, perhaps there's old configurations somewhere ?
thoughts ?
thanks
12-15-2011 09:43 AM
Aaron,
Call in Cisco Small Business Support and open a support case @ 1-866-606-1866
Jasbryan
