Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
1043
Highlighted
Beginner
RV220W port forwarding help !
Hi,  im going crazy trying to debug this issue..
I have 6 port forwarding rules, they all work except one.   (slingbox, etc)
I have a Win7 PC running an HTTP server on Port 8080,  firewall is turned off on the Win 7 PC.  I have hit and access the service from inside my network.
I have all the rules setup as you would expect, custom service, port forwarding, etc.
Cisco support how can I work with you on debugging this, is there any particular logs I can send
thanks
3 REPLIES 3
Highlighted
Rising star
Hi Aaron,
Thank you for posting. Did you create the rule for http 8080 under Port Forwarding or Access Rules? There is a known issue with Port Forwarding and we recommend that all rules be created under Access Rules until the issue is fixed by a firmware update. After the rule is created it will show up under "Port Forwarding". Also, make sure that the rule is configured like the ones that are working.
Highlighted
I read that issue,  and figured it was the problem,  so I already deleted the custom service definition (8080) and the port forwarding and access rules.. then I recreated just using an access rule.   -- that's my current configuration
I was on an older firmware and moved to this latest version, perhaps there's old configurations somewhere ?
thoughts ?
thanks
Highlighted
Frequent Contributor
Aaron,
Call in Cisco Small Business Support and open a support case @ 1-866-606-1866
Jasbryan
