Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
7387
AlanHardy
Beginner
RV220W port forwarding issues
I am trying to allow incoming requests from the WAN on a RV220W for http, FTP, and a further service on port 8080.
Note: Firmware is v1.0.2.4.
I have tried setting this up under Firewall / Port Forwarding and under Firewall / Rules.
Despite this, there is no access from outside. I had this all working quite happily with a Dynalink RTA1046VW, which was running the network previously.
Are there known issues which may be affecting this? Suggestions welcome
Alan
8 REPLIES 8
Jens Janssen
Beginner
Hi Alan,
there is a bug described in the 1.0.2.4 release notes:
Internet NAT redirection does not work using firewall port-forwarding rules.
A LAN client cannot access a service by using the WAN IP address of the
LAN device (such as an IP camera or an FTP server).
Work Around: Do not use the Firewall > Port Forwarding page, but instead
create the forwarding rule by using the Firewall > Access Rules page. The
working port forwarding entry is created along with the firewall access rule.
Jens
I had noticed that bug and tried adding the exception under Firewall / Access Rules. But still no go.
The details of the rule for HTTP is as follows:
Add / Edit Access Rule Configuration
Connection Type:
Action:
Schedule:
Service:
Source IP:
Start:
Finish:
Destination IP:
Start:
Finish:
Use This SNAT IP Address:
Enable
SNAT IP:
Send to Local Server (DNAT IP):17.23.50.10
Use Other WAN (Internet) IP Address:
Enable
WAN (Internet) Destination IP:
Rule Status:
Is anything amiss there?
do you still have any port forwarding enabled?  it maybe conflicting.  http rules works on my RV220W.  I can only suggest you try to reset the router to factory defaults and try again.
Regards Simon
Same thing on my RV220W with firmware 1.0.2.4. When I create a new firewall rule for HTTPS forwarding, the appropriate port forwarding rule will be generated automatically. So no way to get port 443 open for incoming connections.
Thomas
If 17.23.50.10 is the internal IP of your server and port 80 is waiting for requests then everything is correct.
For me this woks as expected. I'm using dynDNS + Reverse Proxy behind port 80.
I too have been knocking my head trying to get this figured out. Not to sound like a stupid question, but is the DNAT address that of the router, or of the machine that you are trying to set the port up for? Right now I have it set at the router IP, thinking that it is doing the NAT duties.
Thanks for any help!
Ron
I've tried everything here and in similar forums, even with 1.0.1.0 and 1.0.2.4, and none of them I have succeeded.
what I'm trying is to get up my FTP server with port forwarding, will also have a small web server (for local USE)
I get in touch with my FTP server locally, but always ends with "Time out"
This will log using FileZilla:
Status: Connecting to 192.168.1.199:21 ...
Status: Connection established, waiting for welcome message ...
Answer: 220 vsftpd 2.0.4 + (ext.3) ready ...
Command: USER admin
Response: 331 Please specify the password.
Command: PASS *********
Response: 230 Login Successful.
Command: SYST
Response: 215 UNIX Type: L8
Command: FEAT
Answer: 211-Features:
Response: EPRT
Answer: EPSV
Response: MDTM
Answer: PASV
Response: UTF8
Response: REST STREAM
Response: SIZE
Answer: TVFS
Response: 211 End
Command: opts UTF8 ON
Response: 200 UTF8 option is on.
Status: Connected
Status: Retrieving directory listing ...
Command: PWD
Response: 257 "/"
Command: TYPE I
Response: 200 Switching to Binary mode.
Command: PASV
Error: Connection closed by server
Error: Failed to retrieve directory listing
But all this works great with my D-Link DIR-655
Want to trade up to me a little more stabiulare router so I chose this, either I get to go back to my D-Link
or you can get any sensible answers here?
AlanHardy
Beginner
This issue has been resolved.
The router was having a problem with the IP range being used, which was 17.23.50.xxx.
When I changed the IP range to 172.23.50.xxx, port forwarding worked as instructed.
My thanks go to Gleb Sharkunov from Cisco Support for this suggestion.
