rv220w pptp remote connection use two ip address
jwildog0079
                   Hello, I am a long time quick vpn user. I recently purchased a new windows 8.1 pro and the quickvpn fails. After many searches It appears this is a know issue and I should look for another way to connect. I choose to use the PPTP option. I set it up and everything it going well. however I have one slight issues when I try to use an ip specific software on my system that has remotely made the vpn pptp connection. I ran the cmd and check the ipconfig and see now that my computer has two ip address one from the air card I am using to connect to the internet 192.168.0.192 and one that the pptp vpn connection assigns 10.0.0.21 my issue is for my ip specific software to work I am forced to register both ip address for the same computer and each license from the vendor is good for one computer one ip address so this is going to double my operating cost. can anyone help.
Please let me know if you need more info I will do my best to gather. Thanks in advance.
10 Replies 10
jwildog0079
This question came up today while seaking a resolution with my software vendor. to get away from the ip address issuse.
can anyone tell me how to set the router up while the pptp vpn connection is active to allow the the pc name to pass through with a net bios broadcast?
Hi Jared,
The easiest way is to edit the hosts file:
http://helpdeskgeek.com/windows-7/windows-7-hosts-file/
http://www.howtogeek.com/howto/27350/beginner-geek-how-to-edit-your-hosts-file/
Regarding your first question, I'm not sure that there is a way to get around the multiple IP address issue with PPTP. What kind of software are you using? QuickVPN is a better solution in your case because no extra address is assigned. Have you tried to make QuickVPN work with Windows 8.1? I have read some posts where people claim to have it working. I was able to make it work with Windows 8 on a laptop that has since failed so I no longer have access to it. If I recall correctly I had to create custom firewall rules to allow ICMP (ping) inbound and outbound. QuickVPN is not officially supported on Windows 8.1, so make changes at your own risk.
- Marty
Marty,
Thanks. I am out today but will try to edit the host file tomorrow and test.
Marty,
I logged in to the UNIX server and edited the hosts file as
10.0.0.21 envy00 #ip assigned by vpn
192.168.243.256 envy00 #ip assigned by aircard
Is that what you had meant for me to do as this did not resolve my issues of being able to find my pc by pc name nor did it make it possible for the software to see my pc by a single ip.
I also logged into the router and went to the add firewall rule there are icmp-type-3 through icmp-type-13 so are you saying I have to add 10 rules one for each type in an attempt to force the quickvpn to work?
I have not found a single posting for which anyone claims to have found a solution for the quickvpn but I have seen solutions for the Cisco vpn client however my reg key are not as described.
If you could offer any more help thanks again in advance.
I was able to make a quickvpn connection to my rv220w router via a wifi connection. I am unsure of the exact change made and I am now wondering if anyone can review this log and tell me what happened to allow the connection. At first I was very taken back and had to triple check to make sure it was working. Below is today’s router log at 18:00 I was able to make a successful quickvpn connection. Anyone see how? The rest of the morning I was trying repeatedly to make a connection
is this important? "
2014-02-01 19:04:31: [rv220w][IKE] INFO:  Ignoring request for negotiation to 166.142.243.242 as Local is configured as Responder.
2000-01-01 00:00:36: [rv220w][IKE] INFO:  IKE started
2014-02-01 12:47:49: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "joey01"
2014-02-01 12:47:49: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "joey01"
2014-02-01 12:47:59: [rv220w][IKE] INFO:  Configuration found for 166.155.0.67[500].
2014-02-01 12:47:59: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[500]<=>166.155.0.67[500]
2014-02-01 12:47:59: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 12:47:59: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 12:47:59: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 12:47:59: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 12:48:00: [rv220w][IKE] INFO:  For 166.155.0.67[500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 12:48:00: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[500]
2014-02-01 12:48:00: [rv220w][IKE] INFO:  NAT-D payload matches for 166.155.0.67[500]
2014-02-01 12:48:00: [rv220w][IKE] INFO:  NAT detected: ME
2014-02-01 12:48:00: [rv220w][IKE] INFO:  Floating ports for NAT-T with peer 166.155.0.67[4500]
2014-02-01 12:48:00: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-166.155.0.67[4500] with spi:3671b391a56b4bee:52b561ece6e2aa09
2014-02-01 12:48:00: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 12:48:00: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>166.155.0.67[0]
2014-02-01 12:48:00: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.155.0.67/32
2014-02-01 12:48:00: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 12:48:01: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=266310588(0xfdf93bc)
2014-02-01 12:48:01: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=3530213431(0xd26ac837)
2014-02-01 12:49:19: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=3671b391a56b4bee:52b561ece6e2aa09.
2014-02-01 12:49:20: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-166.155.0.67[4500] with spi:3671b391a56b4bee:52b561ece6e2aa09
2014-02-01 13:36:02: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=3530213431(0xd26ac837)
2014-02-01 13:36:02: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=266310588(0xfdf93bc)
2014-02-01 13:46:50: [rv220w][IKE] INFO:  Configuration found for 166.155.0.67[4500].
2014-02-01 13:46:50: [rv220w][IKE] INFO:  Ports floated, peer initiatedcommunication on 4500
2014-02-01 13:46:50: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[4500]<=>166.155.0.67[4500]
2014-02-01 13:46:50: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 13:46:50: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 13:46:50: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 13:46:50: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 13:46:50: [rv220w][IKE] INFO:  For 166.155.0.67[4500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 13:46:50: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[4500]
2014-02-01 13:46:50: [rv220w][IKE] INFO:  NAT-D payload matches for 166.155.0.67[4500]
2014-02-01 13:46:50: [rv220w][IKE] INFO:  NAT detected: ME
2014-02-01 13:46:50: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-166.155.0.67[4500] with spi:1d7d95d359ea4f66:d71a5efcd843af68
2014-02-01 13:46:50: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 13:46:51: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>166.155.0.67[0]
2014-02-01 13:46:51: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.155.0.67/32
2014-02-01 13:46:51: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 13:46:51: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=225127593(0xd6b2ca9)
2014-02-01 13:46:51: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=1534791298(0x5b7b0e82)
2014-02-01 13:48:34: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=1d7d95d359ea4f66:d71a5efcd843af68.
2014-02-01 13:48:35: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-166.155.0.67[4500] with spi:1d7d95d359ea4f66:d71a5efcd843af68
2014-02-01 14:34:01: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "alohavpn"
2014-02-01 14:34:01: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "alohavpn"
2014-02-01 14:34:06: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.250/8<->166.142.243.242/30
2014-02-01 14:34:06: [rv220w][IKE] INFO:  Configuration found for 166.142.243.242.
2014-02-01 14:34:06: [rv220w][IKE] INFO:  Initiating new phase 1 negotiation: 192.168.0.10[500]<=>166.142.243.242[500]
2014-02-01 14:34:06: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 14:34:06: [rv220w][IKE] INFO:   [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2014-02-01 14:34:06: [rv220w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 4
2014-02-01 14:34:06: [rv220w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 8
2014-02-01 14:34:06: [rv220w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 9
2014-02-01 14:34:27: [rv220w][IKE] INFO:  accept a request to establish IKE-SA: 166.142.243.242
2014-02-01 14:34:27: [rv220w][IKE] INFO:  Configuration found for 166.142.243.242.
2014-02-01 14:34:37: [rv220w][IKE] ERROR:  Phase 2 negotiation failed due to time up waiting for phase1. ESP 166.142.243.242->192.168.0.10
2014-02-01 14:34:52: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=1534791298(0x5b7b0e82)
2014-02-01 14:34:52: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=225127593(0xd6b2ca9)
2014-02-01 14:34:58: [rv220w][IKE] ERROR:  Invalid SA protocol type: 0
2014-02-01 14:34:58: [rv220w][IKE] ERROR:  Phase 2 negotiation failed due to time up waiting for phase1.
2014-02-01 14:35:06: [rv220w][IKE] ERROR:  Phase 1 negotiation failed due to time up for 166.142.243.242[500]. a8c862e86c5d65ea:0000000000000000
2014-02-01 14:35:18: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.250/8<->166.142.243.242/30
2014-02-01 14:35:18: [rv220w][IKE] INFO:  Configuration found for 166.142.243.242.
2014-02-01 14:35:18: [rv220w][IKE] INFO:  Initiating new phase 1 negotiation: 192.168.0.10[500]<=>166.142.243.242[500]
2014-02-01 14:35:18: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 14:35:18: [rv220w][IKE] INFO:   [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2014-02-01 14:35:18: [rv220w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 4
2014-02-01 14:35:18: [rv220w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 8
2014-02-01 14:35:18: [rv220w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 9
2014-02-01 14:35:29: [rv220w][IKE] INFO:  an undead schedule has been deleted: 'isakmp_chkph1there'.
2014-02-01 14:35:29: [rv220w][IKE] INFO:  IPSec configuration with identifier "alohavpn" deleted sucessfully
2014-02-01 14:35:29: [rv220w][IKE] WARNING:  no phase2 bounded.
2014-02-01 14:35:29: [rv220w][IKE] INFO:  Purged ISAKMP-SA with spi=44ad4081d881ca39:0000000000000000.
2014-02-01 14:35:29: [rv220w][IKE] INFO:  an undead schedule has been deleted: 'purge_remote'.
2014-02-01 14:35:29: [rv220w][IKE] INFO:  an undead schedule has been deleted: 'isakmp_ph1resend'.
2014-02-01 14:35:29: [rv220w][IKE] INFO:  IKE configuration with identifier "alohavpn" deleted sucessfully
2014-02-01 14:45:36: [rv220w][IKE] INFO:  Configuration found for 166.155.0.67[4500].
2014-02-01 14:45:36: [rv220w][IKE] INFO:  Ports floated, peer initiatedcommunication on 4500
2014-02-01 14:45:36: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[4500]<=>166.155.0.67[4500]
2014-02-01 14:45:36: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 14:45:36: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 14:45:36: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 14:45:36: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 14:45:36: [rv220w][IKE] INFO:  For 166.155.0.67[4500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 14:45:37: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[4500]
2014-02-01 14:45:37: [rv220w][IKE] INFO:  NAT-D payload matches for 166.155.0.67[4500]
2014-02-01 14:45:37: [rv220w][IKE] INFO:  NAT detected: ME
2014-02-01 14:45:37: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-166.155.0.67[4500] with spi:e7ff5eebc74fe18e:26a523a055bdd961
2014-02-01 14:45:37: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 14:45:37: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>166.155.0.67[0]
2014-02-01 14:45:37: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.155.0.67/32
2014-02-01 14:45:37: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 14:45:38: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=233645680(0xded2670)
2014-02-01 14:45:38: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=3473253380(0xcf05a404)
2014-02-01 14:47:04: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=e7ff5eebc74fe18e:26a523a055bdd961.
2014-02-01 14:47:05: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-166.155.0.67[4500] with spi:e7ff5eebc74fe18e:26a523a055bdd961
2014-02-01 14:49:00: [rv220w][IKE] ERROR:  Could not find configuration for 99.120.21.158[500]
2014-02-01 14:49:01: [rv220w][IKE] ERROR:  Could not find configuration for 99.120.21.158[500]
2014-02-01 14:49:03: [rv220w][IKE] ERROR:  Could not find configuration for 99.120.21.158[500]
2014-02-01 14:49:07: [rv220w][IKE] ERROR:  Could not find configuration for 99.120.21.158[500]
2014-02-01 14:49:42: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "tim000"
2014-02-01 14:49:42: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "tim000"
2014-02-01 14:49:44: [rv220w][IKE] INFO:  Configuration found for 99.120.21.158[500].
2014-02-01 14:49:44: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[500]<=>99.120.21.158[500]
2014-02-01 14:49:44: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 14:49:44: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 14:49:44: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 14:49:44: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 14:49:44: [rv220w][IKE] INFO:  For 99.120.21.158[500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 14:49:44: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[500]
2014-02-01 14:49:44: [rv220w][IKE] INFO:  NAT-D payload does not match for 99.120.21.158[500]
2014-02-01 14:49:44: [rv220w][IKE] INFO:  NAT detected: ME PEER
2014-02-01 14:49:44: [rv220w][IKE] INFO:  Floating ports for NAT-T with peer 99.120.21.158[4500]
2014-02-01 14:49:44: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-99.120.21.158[4500] with spi:c37856d7496f4bc0:d866a785808f18ff
2014-02-01 14:49:44: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 14:49:45: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>99.120.21.158[0]
2014-02-01 14:49:45: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->192.168.1.68/32
2014-02-01 14:49:45: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 14:49:45: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 99.120.21.158->192.168.0.10 with spi=201496659(0xc029853)
2014-02-01 14:49:45: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->99.120.21.158 with spi=3623586341(0xd7fb8a25)
2014-02-01 14:51:02: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=c37856d7496f4bc0:d866a785808f18ff.
2014-02-01 14:51:03: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-99.120.21.158[4500] with spi:c37856d7496f4bc0:d866a785808f18ff
2014-02-01 15:33:39: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=3473253380(0xcf05a404)
2014-02-01 15:33:39: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=233645680(0xded2670)
2014-02-01 15:37:46: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->99.120.21.158 with spi=3623586341(0xd7fb8a25)
2014-02-01 15:37:46: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 99.120.21.158->192.168.0.10 with spi=201496659(0xc029853)
2014-02-01 15:38:35: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "happy00"
2014-02-01 15:38:35: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "happy00"
2014-02-01 15:38:55: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.142.243.242/32
2014-02-01 15:38:55: [rv220w][IKE] INFO:  Configuration found for 166.142.243.242.
2014-02-01 15:38:55: [rv220w][IKE] INFO:  Ignoring request for negotiation to 166.142.243.242 as Local is configured as Responder.
2014-02-01 15:40:28: [rv220w][IKE] INFO:  IPSec configuration with identifier "happy00" deleted sucessfully
2014-02-01 15:40:28: [rv220w][IKE] WARNING:  no phase1 found for "happy00"
2014-02-01 15:40:28: [rv220w][IKE] INFO:  IKE configuration with identifier "happy00" deleted sucessfully
2014-02-01 15:40:28: [rv220w][IKE] ERROR:  sainfo identifier not found ("happy00")
2014-02-01 15:40:28: [rv220w][IKE] ERROR:  Failed to Delete the IPSec configuration with identifier "happy00"
2014-02-01 15:40:28: [rv220w][IKE] ERROR:  remote identifier not found ("")
2014-02-01 15:40:28: [rv220w][IKE] ERROR:  Failed to Delete the IKE configuration with identifier ""
2014-02-01 15:40:47: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "happy00"
2014-02-01 15:40:47: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "happy00"
2014-02-01 15:40:55: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.142.243.242/32
2014-02-01 15:40:55: [rv220w][IKE] INFO:  Configuration found for 166.142.243.242.
2014-02-01 15:40:55: [rv220w][IKE] INFO:  Ignoring request for negotiation to 166.142.243.242 as Local is configured as Responder.
2014-02-01 15:44:52: [rv220w][IKE] WARNING:  no phase2 found for "joey01"
2014-02-01 15:44:52: [rv220w][IKE] INFO:  IPSec configuration with identifier "joey01" deleted sucessfully
2014-02-01 15:44:52: [rv220w][IKE] WARNING:  no phase1 found for "joey01"
2014-02-01 15:44:52: [rv220w][IKE] INFO:  IKE configuration with identifier "joey01" deleted sucessfully
2014-02-01 15:44:52: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "joey01"
2014-02-01 15:44:52: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "joey01"
2014-02-01 15:45:02: [rv220w][IKE] INFO:  Configuration found for 166.155.0.67[500].
2014-02-01 15:45:02: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[500]<=>166.155.0.67[500]
2014-02-01 15:45:02: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 15:45:02: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 15:45:02: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 15:45:02: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 15:45:02: [rv220w][IKE] INFO:  For 166.155.0.67[500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 15:45:03: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[500]
2014-02-01 15:45:03: [rv220w][IKE] INFO:  NAT-D payload matches for 166.155.0.67[500]
2014-02-01 15:45:03: [rv220w][IKE] INFO:  NAT detected: ME
2014-02-01 15:45:03: [rv220w][IKE] INFO:  Floating ports for NAT-T with peer 166.155.0.67[4500]
2014-02-01 15:45:03: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-166.155.0.67[4500] with spi:26214a2b8fde97de:0f3107405c30ec29
2014-02-01 15:45:03: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 15:45:03: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>166.155.0.67[0]
2014-02-01 15:45:03: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.155.0.67/32
2014-02-01 15:45:03: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 15:45:04: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=171519328(0xa392d60)
2014-02-01 15:45:04: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=995888774(0x3b5c0e86)
2014-02-01 15:46:19: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=26214a2b8fde97de:0f3107405c30ec29.
2014-02-01 15:46:20: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-166.155.0.67[4500] with spi:26214a2b8fde97de:0f3107405c30ec29
2014-02-01 15:47:22: [rv220w][IKE] INFO:  IPSec configuration with identifier "happy00" deleted sucessfully
2014-02-01 15:47:22: [rv220w][IKE] WARNING:  no phase1 found for "happy00"
2014-02-01 15:47:22: [rv220w][IKE] INFO:  IKE configuration with identifier "happy00" deleted sucessfully
2014-02-01 15:47:22: [rv220w][IKE] ERROR:  sainfo identifier not found ("happy00")
2014-02-01 15:47:22: [rv220w][IKE] ERROR:  Failed to Delete the IPSec configuration with identifier "happy00"
2014-02-01 15:47:22: [rv220w][IKE] ERROR:  remote identifier not found ("")
2014-02-01 15:47:22: [rv220w][IKE] ERROR:  Failed to Delete the IKE configuration with identifier ""
2014-02-01 15:48:37: [rv220w][IKE] INFO:  Configuration found for 99.120.21.158[4500].
2014-02-01 15:48:37: [rv220w][IKE] INFO:  Ports floated, peer initiatedcommunication on 4500
2014-02-01 15:48:37: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[4500]<=>99.120.21.158[4500]
2014-02-01 15:48:37: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 15:48:37: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 15:48:37: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 15:48:37: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 15:48:37: [rv220w][IKE] INFO:  For 99.120.21.158[4500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 15:48:37: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[4500]
2014-02-01 15:48:37: [rv220w][IKE] INFO:  NAT-D payload does not match for 99.120.21.158[4500]
2014-02-01 15:48:37: [rv220w][IKE] INFO:  NAT detected: ME PEER
2014-02-01 15:48:37: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-99.120.21.158[4500] with spi:95b646cb75adbb50:0ed9f31398ea14aa
2014-02-01 15:48:37: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 15:48:37: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>99.120.21.158[0]
2014-02-01 15:48:37: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->192.168.1.68/32
2014-02-01 15:48:37: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 15:48:38: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 99.120.21.158->192.168.0.10 with spi=254599107(0xf2cdfc3)
2014-02-01 15:48:38: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->99.120.21.158 with spi=2917092721(0xaddf4d71)
2014-02-01 15:50:17: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=95b646cb75adbb50:0ed9f31398ea14aa.
2014-02-01 15:50:18: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-99.120.21.158[4500] with spi:95b646cb75adbb50:0ed9f31398ea14aa
2014-02-01 15:50:23: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "happy00"
2014-02-01 15:50:23: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "happy00"
2014-02-01 15:50:39: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.142.243.242/32
2014-02-01 15:50:39: [rv220w][IKE] INFO:  Configuration found for 166.142.243.242.
2014-02-01 15:50:39: [rv220w][IKE] INFO:  Ignoring request for negotiation to 166.142.243.242 as Local is configured as Responder.
2014-02-01 15:51:12: [rv220w][IKE] INFO:  IPSec configuration with identifier "happy00" deleted sucessfully
2014-02-01 15:51:12: [rv220w][IKE] WARNING:  no phase1 found for "happy00"
2014-02-01 15:51:12: [rv220w][IKE] INFO:  IKE configuration with identifier "happy00" deleted sucessfully
2014-02-01 15:51:12: [rv220w][IKE] ERROR:  sainfo identifier not found ("happy00")
2014-02-01 15:51:12: [rv220w][IKE] ERROR:  Failed to Delete the IPSec configuration with identifier "happy00"
2014-02-01 15:51:12: [rv220w][IKE] ERROR:  remote identifier not found ("")
2014-02-01 15:51:12: [rv220w][IKE] ERROR:  Failed to Delete the IKE configuration with identifier ""
2014-02-01 16:33:05: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=995888774(0x3b5c0e86)
2014-02-01 16:33:05: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=171519328(0xa392d60)
2014-02-01 16:36:39: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->99.120.21.158 with spi=2917092721(0xaddf4d71)
2014-02-01 16:36:39: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 99.120.21.158->192.168.0.10 with spi=254599107(0xf2cdfc3)
2014-02-01 16:43:50: [rv220w][IKE] INFO:  Configuration found for 166.155.0.67[4500].
2014-02-01 16:43:50: [rv220w][IKE] INFO:  Ports floated, peer initiatedcommunication on 4500
2014-02-01 16:43:50: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[4500]<=>166.155.0.67[4500]
2014-02-01 16:43:50: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 16:43:50: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 16:43:50: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 16:43:50: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 16:43:50: [rv220w][IKE] INFO:  For 166.155.0.67[4500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 16:43:50: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[4500]
2014-02-01 16:43:50: [rv220w][IKE] INFO:  NAT-D payload matches for 166.155.0.67[4500]
2014-02-01 16:43:50: [rv220w][IKE] INFO:  NAT detected: ME
2014-02-01 16:43:50: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-166.155.0.67[4500] with spi:6a803bd2c559ba70:d005a2ba6e84b619
2014-02-01 16:43:50: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 16:43:50: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>166.155.0.67[0]
2014-02-01 16:43:50: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.155.0.67/32
2014-02-01 16:43:50: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 16:43:51: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=98566123(0x5dfffeb)
2014-02-01 16:43:51: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=3231695043(0xc09fc0c3)
2014-02-01 16:45:28: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=6a803bd2c559ba70:d005a2ba6e84b619.
2014-02-01 16:45:29: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-166.155.0.67[4500] with spi:6a803bd2c559ba70:d005a2ba6e84b619
2014-02-01 16:47:29: [rv220w][IKE] INFO:  Configuration found for 99.120.21.158[4500].
2014-02-01 16:47:29: [rv220w][IKE] INFO:  Ports floated, peer initiatedcommunication on 4500
2014-02-01 16:47:29: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[4500]<=>99.120.21.158[4500]
2014-02-01 16:47:29: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 16:47:29: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 16:47:29: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 16:47:29: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 16:47:29: [rv220w][IKE] INFO:  For 99.120.21.158[4500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 16:47:29: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[4500]
2014-02-01 16:47:29: [rv220w][IKE] INFO:  NAT-D payload does not match for 99.120.21.158[4500]
2014-02-01 16:47:29: [rv220w][IKE] INFO:  NAT detected: ME PEER
2014-02-01 16:47:29: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-99.120.21.158[4500] with spi:6852c876e1425084:944da52b84937c9a
2014-02-01 16:47:29: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 16:47:29: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>99.120.21.158[0]
2014-02-01 16:47:29: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->192.168.1.68/32
2014-02-01 16:47:30: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 16:47:30: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 99.120.21.158->192.168.0.10 with spi=103279842(0x627ece2)
2014-02-01 16:47:30: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->99.120.21.158 with spi=2492252444(0x948cc11c)
2014-02-01 16:48:47: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=6852c876e1425084:944da52b84937c9a.
2014-02-01 16:48:48: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-99.120.21.158[4500] with spi:6852c876e1425084:944da52b84937c9a
2014-02-01 17:31:52: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=3231695043(0xc09fc0c3)
2014-02-01 17:31:52: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=98566123(0x5dfffeb)
2014-02-01 17:35:31: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->99.120.21.158 with spi=2492252444(0x948cc11c)
2014-02-01 17:35:31: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 99.120.21.158->192.168.0.10 with spi=103279842(0x627ece2)
2014-02-01 17:42:40: [rv220w][IKE] INFO:  Configuration found for 166.155.0.67[4500].
2014-02-01 17:42:40: [rv220w][IKE] INFO:  Ports floated, peer initiatedcommunication on 4500
2014-02-01 17:42:40: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[4500]<=>166.155.0.67[4500]
2014-02-01 17:42:40: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 17:42:40: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 17:42:40: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 17:42:40: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 17:42:40: [rv220w][IKE] INFO:  For 166.155.0.67[4500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 17:42:40: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[4500]
2014-02-01 17:42:40: [rv220w][IKE] INFO:  NAT-D payload matches for 166.155.0.67[4500]
2014-02-01 17:42:40: [rv220w][IKE] INFO:  NAT detected: ME
2014-02-01 17:42:41: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-166.155.0.67[4500] with spi:610f4e8b8a701292:1b5b4fac9129d2cc
2014-02-01 17:42:41: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 17:42:41: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>166.155.0.67[0]
2014-02-01 17:42:41: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.155.0.67/32
2014-02-01 17:42:41: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 17:42:41: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=5442197(0x530a95)
2014-02-01 17:42:41: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=281087573(0x10c10e55)
2014-02-01 17:43:58: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=610f4e8b8a701292:1b5b4fac9129d2cc.
2014-02-01 17:43:59: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-166.155.0.67[4500] with spi:610f4e8b8a701292:1b5b4fac9129d2cc
2014-02-01 17:46:24: [rv220w][IKE] INFO:  Configuration found for 99.120.21.158[4500].
2014-02-01 17:46:24: [rv220w][IKE] INFO:  Ports floated, peer initiatedcommunication on 4500
2014-02-01 17:46:24: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[4500]<=>99.120.21.158[4500]
2014-02-01 17:46:24: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 17:46:24: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 17:46:24: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 17:46:24: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 17:46:24: [rv220w][IKE] INFO:  For 99.120.21.158[4500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 17:46:24: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[4500]
2014-02-01 17:46:24: [rv220w][IKE] INFO:  NAT-D payload does not match for 99.120.21.158[4500]
2014-02-01 17:46:24: [rv220w][IKE] INFO:  NAT detected: ME PEER
2014-02-01 17:46:25: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-99.120.21.158[4500] with spi:34fbdc2521b83861:4f04939eefba3853
2014-02-01 17:46:25: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 17:46:25: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>99.120.21.158[0]
2014-02-01 17:46:25: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->192.168.1.68/32
2014-02-01 17:46:25: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 17:46:25: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 99.120.21.158->192.168.0.10 with spi=232320279(0xdd8ed17)
2014-02-01 17:46:25: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->99.120.21.158 with spi=2789259203(0xa640b7c3)
2014-02-01 17:48:02: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=34fbdc2521b83861:4f04939eefba3853.
2014-02-01 17:48:03: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-99.120.21.158[4500] with spi:34fbdc2521b83861:4f04939eefba3853
2014-02-01 18:30:42: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=281087573(0x10c10e55)
2014-02-01 18:30:42: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=5442197(0x530a95)
2014-02-01 18:34:26: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->99.120.21.158 with spi=2789259203(0xa640b7c3)
2014-02-01 18:34:26: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 99.120.21.158->192.168.0.10 with spi=232320279(0xdd8ed17)
2014-02-01 18:41:21: [rv220w][IKE] INFO:  Configuration found for 166.155.0.67[4500].
2014-02-01 18:41:21: [rv220w][IKE] INFO:  Ports floated, peer initiatedcommunication on 4500
2014-02-01 18:41:21: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[4500]<=>166.155.0.67[4500]
2014-02-01 18:41:21: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 18:41:21: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 18:41:21: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 18:41:21: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 18:41:21: [rv220w][IKE] INFO:  For 166.155.0.67[4500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 18:41:21: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[4500]
2014-02-01 18:41:21: [rv220w][IKE] INFO:  NAT-D payload matches for 166.155.0.67[4500]
2014-02-01 18:41:21: [rv220w][IKE] INFO:  NAT detected: ME
2014-02-01 18:41:22: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-166.155.0.67[4500] with spi:11605c3a8435559f:38b8c86ef5bc8173
2014-02-01 18:41:22: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 18:41:22: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>166.155.0.67[0]
2014-02-01 18:41:22: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.155.0.67/32
2014-02-01 18:41:22: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 18:41:22: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=116125724(0x6ebf01c)
2014-02-01 18:41:22: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=712542982(0x2a788b06)
2014-02-01 18:43:05: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=11605c3a8435559f:38b8c86ef5bc8173.
2014-02-01 18:43:06: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-166.155.0.67[4500] with spi:11605c3a8435559f:38b8c86ef5bc8173
2014-02-01 18:45:11: [rv220w][IKE] INFO:  Configuration found for 99.120.21.158[4500].
2014-02-01 18:45:11: [rv220w][IKE] INFO:  Ports floated, peer initiatedcommunication on 4500
2014-02-01 18:45:11: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[4500]<=>99.120.21.158[4500]
2014-02-01 18:45:11: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 18:45:11: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 18:45:11: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 18:45:11: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 18:45:11: [rv220w][IKE] INFO:  For 99.120.21.158[4500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 18:45:11: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[4500]
2014-02-01 18:45:11: [rv220w][IKE] INFO:  NAT-D payload does not match for 99.120.21.158[4500]
2014-02-01 18:45:11: [rv220w][IKE] INFO:  NAT detected: ME PEER
2014-02-01 18:45:11: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-99.120.21.158[4500] with spi:78a21d9a6ff7a028:d143c9317afa091b
2014-02-01 18:45:11: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 18:45:11: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>99.120.21.158[0]
2014-02-01 18:45:11: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->192.168.1.68/32
2014-02-01 18:45:11: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 18:45:12: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 99.120.21.158->192.168.0.10 with spi=129883376(0x7bddcf0)
2014-02-01 18:45:12: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->99.120.21.158 with spi=654476335(0x2702842f)
2014-02-01 18:46:32: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=78a21d9a6ff7a028:d143c9317afa091b.
2014-02-01 18:46:33: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-99.120.21.158[4500] with spi:78a21d9a6ff7a028:d143c9317afa091b
2014-02-01 19:04:30: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "happy00"
2014-02-01 19:04:30: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "happy00"
2014-02-01 19:04:31: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.142.243.242/32
2014-02-01 19:04:31: [rv220w][IKE] INFO:  Configuration found for 166.142.243.242.
2014-02-01 19:05:13: [rv220w][IKE] INFO:  IPSec configuration with identifier "happy00" deleted sucessfully
2014-02-01 19:05:13: [rv220w][IKE] WARNING:  no phase1 found for "happy00"
2014-02-01 19:05:13: [rv220w][IKE] INFO:  IKE configuration with identifier "happy00" deleted sucessfully
2014-02-01 19:05:14: [rv220w][IKE] ERROR:  sainfo identifier not found ("happy00")
2014-02-01 19:05:14: [rv220w][IKE] ERROR:  Failed to Delete the IPSec configuration with identifier "happy00"
2014-02-01 19:05:14: [rv220w][IKE] ERROR:  remote identifier not found ("")
2014-02-01 19:05:14: [rv220w][IKE] ERROR:  Failed to Delete the IKE configuration with identifier ""
2014-02-01 19:05:53: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "happy00"
2014-02-01 19:05:53: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "happy00"
2014-02-01 19:06:07: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.142.243.242/32
2014-02-01 19:06:07: [rv220w][IKE] INFO:  Configuration found for 166.142.243.242.
2014-02-01 19:06:07: [rv220w][IKE] INFO:  Ignoring request for negotiation to 166.142.243.242 as Local is configured as Responder.
2014-02-01 19:06:27: [rv220w][IKE] INFO:  IPSec configuration with identifier "happy00" deleted sucessfully
2014-02-01 19:06:27: [rv220w][IKE] WARNING:  no phase1 found for "happy00"
2014-02-01 19:06:27: [rv220w][IKE] INFO:  IKE configuration with identifier "happy00" deleted sucessfully
2014-02-01 19:06:27: [rv220w][IKE] ERROR:  sainfo identifier not found ("happy00")
2014-02-01 19:06:27: [rv220w][IKE] ERROR:  Failed to Delete the IPSec configuration with identifier "happy00"
2014-02-01 19:06:27: [rv220w][IKE] ERROR:  remote identifier not found ("")
2014-02-01 19:06:27: [rv220w][IKE] ERROR:  Failed to Delete the IKE configuration with identifier ""
2014-02-01 19:09:21: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "happy00"
2014-02-01 19:09:21: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "happy00"
2014-02-01 19:09:33: [rv220w][IKE] INFO:  Configuration found for 99.101.94.86[500].
2014-02-01 19:09:33: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[500]<=>99.101.94.86[500]
2014-02-01 19:09:33: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 19:09:33: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 19:09:33: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 19:09:33: [rv220w][IKE] INFO:  Received Vendor ID: RFC 3947
2014-02-01 19:09:33: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 19:09:33: [rv220w][IKE] INFO:  For 99.101.94.86[500], Selected NAT-T version: RFC 3947
2014-02-01 19:09:33: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[500]
2014-02-01 19:09:33: [rv220w][IKE] INFO:  NAT-D payload does not match for 99.101.94.86[500]
2014-02-01 19:09:33: [rv220w][IKE] INFO:  NAT detected: ME PEER
2014-02-01 19:09:34: [rv220w][IKE] INFO:  Configuration found for 99.101.94.86[500].
2014-02-01 19:09:34: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[500]<=>99.101.94.86[500]
2014-02-01 19:09:34: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 19:09:34: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 19:09:34: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 19:09:34: [rv220w][IKE] INFO:  Received Vendor ID: RFC 3947
2014-02-01 19:09:34: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 19:09:34: [rv220w][IKE] INFO:  For 99.101.94.86[500], Selected NAT-T version: RFC 3947
2014-02-01 19:09:34: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[500]
2014-02-01 19:09:34: [rv220w][IKE] INFO:  NAT-D payload does not match for 99.101.94.86[500]
2014-02-01 19:09:34: [rv220w][IKE] INFO:  NAT detected: ME PEER
2014-02-01 19:09:34: [rv220w][IKE] INFO:  Floating ports for NAT-T with peer 99.101.94.86[4500]
2014-02-01 19:09:34: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-99.101.94.86[4500] with spi:c45d81319a7961c2:df7f2a51e8084be5
2014-02-01 19:09:34: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 19:09:34: [rv220w][IKE] NOTIFY:  The packet is retransmitted by 99.101.94.86[500].
2014-02-01 19:09:35: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>99.101.94.86[0]
2014-02-01 19:09:35: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->192.168.0.192/32
2014-02-01 19:09:35: [rv220w][IKE] INFO:  Adjusting peer's encmode 3(3)->Tunnel(1)
2014-02-01 19:09:35: [rv220w][IKE] INFO:  Floating ports for NAT-T with peer 99.101.94.86[4500]
2014-02-01 19:09:35: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-99.101.94.86[4500] with spi:51bf7e3f5283a021:c319b19d85b0abd0
2014-02-01 19:09:35: [rv220w][IKE] ERROR:  wrong state 8.
2014-02-01 19:09:35: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 99.101.94.86->192.168.0.10 with spi=43713598(0x29b043e)
2014-02-01 19:09:35: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->99.101.94.86 with spi=2920045730(0xae0c5ca2)
2014-02-01 19:10:33: [rv220w][IKE] INFO:  Configuration found for 99.101.94.86[500].
2014-02-01 19:10:33: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[500]<=>99.101.94.86[500]
2014-02-01 19:10:33: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 19:10:33: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 19:10:33: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 19:10:33: [rv220w][IKE] INFO:  Received Vendor ID: RFC 3947
2014-02-01 19:10:33: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 19:10:33: [rv220w][IKE] INFO:  For 99.101.94.86[500], Selected NAT-T version: RFC 3947
2014-02-01 19:10:33: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=51bf7e3f5283a021:c319b19d85b0abd0.
2014-02-01 19:10:33: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[500]
2014-02-01 19:10:33: [rv220w][IKE] INFO:  NAT-D payload does not match for 99.101.94.86[500]
2014-02-01 19:10:33: [rv220w][IKE] INFO:  NAT detected: ME PEER
2014-02-01 19:10:33: [rv220w][IKE] INFO:  Floating ports for NAT-T with peer 99.101.94.86[4500]
2014-02-01 19:10:33: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-99.101.94.86[4500] with spi:518570911a48e055:e1b21587fbe64a7d
2014-02-01 19:10:34: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-99.101.94.86[4500] with spi:51bf7e3f5283a021:c319b19d85b0abd0
2014-02-01 19:11:31: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=518570911a48e055:e1b21587fbe64a7d.
2014-02-01 19:11:32: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-99.101.94.86[4500] with spi:518570911a48e055:e1b21587fbe64a7d
2014-02-01 19:29:23: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=712542982(0x2a788b06)
2014-02-01 19:29:23: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=116125724(0x6ebf01c)
2014-02-01 19:33:13: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->99.120.21.158 with spi=654476335(0x2702842f)
2014-02-01 19:33:13: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 99.120.21.158->192.168.0.10 with spi=129883376(0x7bddcf0)
2014-02-01 19:40:16: [rv220w][IKE] INFO:  Configuration found for 166.155.0.67[4500].
2014-02-01 19:40:16: [rv220w][IKE] INFO:  Ports floated, peer initiatedcommunication on 4500
2014-02-01 19:40:16: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[4500]<=>166.155.0.67[4500]
2014-02-01 19:40:16: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 19:40:16: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 19:40:16: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 19:40:16: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 19:40:16: [rv220w][IKE] INFO:  For 166.155.0.67[4500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 19:40:16: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[4500]
2014-02-01 19:40:16: [rv220w][IKE] INFO:  NAT-D payload matches for 166.155.0.67[4500]
2014-02-01 19:40:16: [rv220w][IKE] INFO:  NAT detected: ME
2014-02-01 19:40:16: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-166.155.0.67[4500] with spi:86a51befd7ee8b38:1c072d85c8c7ab2e
2014-02-01 19:40:16: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 19:40:16: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>166.155.0.67[0]
2014-02-01 19:40:16: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.155.0.67/32
2014-02-01 19:40:16: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 19:40:17: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 166.155.0.67->192.168.0.10 with spi=131309239(0x7d39eb7)
2014-02-01 19:40:17: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->166.155.0.67 with spi=656105156(0x271b5ec4)
2014-02-01 19:41:35: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=86a51befd7ee8b38:1c072d85c8c7ab2e.
2014-02-01 19:41:36: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-166.155.0.67[4500] with spi:86a51befd7ee8b38:1c072d85c8c7ab2e
2014-02-01 19:43:57: [rv220w][IKE] INFO:  Configuration found for 99.120.21.158[4500].
2014-02-01 19:43:57: [rv220w][IKE] INFO:  Ports floated, peer initiatedcommunication on 4500
2014-02-01 19:43:57: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[4500]<=>99.120.21.158[4500]
2014-02-01 19:43:57: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 19:43:57: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 19:43:57: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 19:43:57: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 19:43:57: [rv220w][IKE] INFO:  For 99.120.21.158[4500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 19:43:57: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[4500]
2014-02-01 19:43:57: [rv220w][IKE] INFO:  NAT-D payload does not match for 99.120.21.158[4500]
2014-02-01 19:43:57: [rv220w][IKE] INFO:  NAT detected: ME PEER
2014-02-01 19:43:57: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-99.120.21.158[4500] with spi:e1442468d0529bbe:f66c9601351bd3a2
2014-02-01 19:43:57: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 19:43:57: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>99.120.21.158[0]
2014-02-01 19:43:57: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->192.168.1.68/32
2014-02-01 19:43:57: [rv220w][IKE] INFO:  Adjusting peer's encmode 61443(61443)->Tunnel(1)
2014-02-01 19:43:58: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 99.120.21.158->192.168.0.10 with spi=191762664(0xb6e10e8)
2014-02-01 19:43:58: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->99.120.21.158 with spi=3118196926(0xb9dbe8be)
2014-02-01 19:45:02: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=e1442468d0529bbe:f66c9601351bd3a2.
2014-02-01 19:45:03: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-99.120.21.158[4500] with spi:e1442468d0529bbe:f66c9601351bd3a2
2014-02-01 19:57:36: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 192.168.0.10->99.101.94.86 with spi=2920045730(0xae0c5ca2)
2014-02-01 19:57:36: [rv220w][IKE] INFO:  IPsec-SA expired: ESP/Tunnel 99.101.94.86->192.168.0.10 with spi=43713598(0x29b043e)
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Configuration found for 99.101.94.86[500].
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[500]<=>99.101.94.86[500]
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Received Vendor ID: RFC 3947
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 19:59:08: [rv220w][IKE] INFO:  For 99.101.94.86[500], Selected NAT-T version: RFC 3947
2014-02-01 19:59:08: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[500]
2014-02-01 19:59:08: [rv220w][IKE] INFO:  NAT-D payload does not match for 99.101.94.86[500]
2014-02-01 19:59:08: [rv220w][IKE] INFO:  NAT detected: ME PEER
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Floating ports for NAT-T with peer 99.101.94.86[4500]
2014-02-01 19:59:08: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-99.101.94.86[4500] with spi:5fbfcd9413b4c0f5:76e81b7495bfa7c8
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Responding to new phase 2 negotiation: 192.168.0.10[0]<=>99.101.94.86[0]
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->192.168.0.192/32
2014-02-01 19:59:08: [rv220w][IKE] INFO:  Adjusting peer's encmode 3(3)->Tunnel(1)
2014-02-01 19:59:09: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 99.101.94.86->192.168.0.10 with spi=267963700(0xff8cd34)
2014-02-01 19:59:09: [rv220w][IKE] INFO:  IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.10->99.101.94.86 with spi=2847327220(0xa9b6c3f4)
2014-02-01 20:04:12: [rv220w][IKE] INFO:  an undead schedule has been deleted: 'pk_recvupdate'.
2014-02-01 20:04:12: [rv220w][IKE] INFO:  Purged IPsec-SA with proto_id=ESP and spi=2847327220(0xa9b6c3f4).
2014-02-01 20:04:12: [rv220w][IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=5fbfcd9413b4c0f5:76e81b7495bfa7c8.
2014-02-01 20:04:13: [rv220w][IKE] WARNING:  no phase2 found for "happy00"
2014-02-01 20:04:13: [rv220w][IKE] INFO:  IPSec configuration with identifier "happy00" deleted sucessfully
2014-02-01 20:04:13: [rv220w][IKE] INFO:  ISAKMP-SA deleted for 192.168.0.10[4500]-99.101.94.86[4500] with spi:5fbfcd9413b4c0f5:76e81b7495bfa7c8
2014-02-01 20:04:13: [rv220w][IKE] WARNING:  no phase2 bounded.
2014-02-01 20:04:13: [rv220w][IKE] INFO:  Sending Informational Exchange: delete payload[]
2014-02-01 20:04:13: [rv220w][IKE] INFO:  Purged IPsec-SA with spi=2920045730(0xae0c5ca2).
2014-02-01 20:04:13: [rv220w][IKE] INFO:  Purged IPsec-SA with spi=267963700(0xff8cd34).
2014-02-01 20:04:13: [rv220w][IKE] INFO:  Purged IPsec-SA with spi=43713598(0x29b043e).
2014-02-01 20:04:13: [rv220w][IKE] INFO:  Purged ISAKMP-SA with spi=c45d81319a7961c2:df7f2a51e8084be5.
2014-02-01 20:04:13: [rv220w][IKE] INFO:  an undead schedule has been deleted: 'purge_remote'.
2014-02-01 20:04:13: [rv220w][IKE] INFO:  IKE configuration with identifier "happy00" deleted sucessfully
2014-02-01 20:04:13: [rv220w][IKE] ERROR:  sainfo identifier not found ("happy00")
2014-02-01 20:04:13: [rv220w][IKE] ERROR:  Failed to Delete the IPSec configuration with identifier "happy00"
2014-02-01 20:04:13: [rv220w][IKE] ERROR:  remote identifier not found ("")
2014-02-01 20:04:13: [rv220w][IKE] ERROR:  Failed to Delete the IKE configuration with identifier ""
2014-02-01 20:06:01: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "happy00"
2014-02-01 20:06:01: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "happy00"
2014-02-01 20:06:07: [rv220w][IKE] INFO:  Using IPsec SA configuration: 10.0.0.0/8<->166.142.243.242/32
2014-02-01 20:06:07: [rv220w][IKE] INFO:  Configuration found for 166.142.243.242.
2014-02-01 20:06:07: [rv220w][IKE] INFO:  Ignoring request for negotiation to 166.142.243.242 as Local is configured as Responder.
2014-02-01 20:07:25: [rv220w][IKE] INFO:  IPSec configuration with identifier "happy00" deleted sucessfully
2014-02-01 20:07:25: [rv220w][IKE] WARNING:  no phase1 found for "happy00"
2014-02-01 20:07:25: [rv220w][IKE] INFO:  IKE configuration with identifier "happy00" deleted sucessfully
2014-02-01 20:07:25: [rv220w][IKE] ERROR:  sainfo identifier not found ("happy00")
2014-02-01 20:07:25: [rv220w][IKE] ERROR:  Failed to Delete the IPSec configuration with identifier "happy00"
2014-02-01 20:07:25: [rv220w][IKE] ERROR:  remote identifier not found ("")
2014-02-01 20:07:25: [rv220w][IKE] ERROR:  Failed to Delete the IKE configuration with identifier ""
2014-02-01 20:09:58: [rv220w][IKE] INFO:  Adding IPSec configuration with identifier "happy00"
2014-02-01 20:09:58: [rv220w][IKE] INFO:  Adding IKE configuration with identifier "happy00"
2014-02-01 20:10:11: [rv220w][IKE] INFO:  Configuration found for 99.101.94.86[500].
2014-02-01 20:10:11: [rv220w][IKE] INFO:  Received request for new phase 1 negotiation: 192.168.0.10[500]<=>99.101.94.86[500]
2014-02-01 20:10:11: [rv220w][IKE] INFO:  Beginning Identity Protection mode.
2014-02-01 20:10:11: [rv220w][IKE] INFO:  Received unknown Vendor ID
2014-02-01 20:10:11: [rv220w][IKE] INFO:  Received Vendor ID: MS NT5 ISAKMPOAKLEY
2014-02-01 20:10:11: [rv220w][IKE] INFO:  Received Vendor ID: RFC 3947
2014-02-01 20:10:11: [rv220w][IKE] INFO:  Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2014-02-01 20:10:11: [rv220w][IKE] INFO:  For 99.101.94.86[500], Selected NAT-T version: RFC 3947
2014-02-01 20:10:11: [rv220w][IKE] INFO:  NAT-D payload does not match for 192.168.0.10[500]
2014-02-01 20:10:11: [rv220w][IKE] INFO:  NAT-D payload does not match for 99.101.94.86[500]
2014-02-01 20:10:11: [rv220w][IKE] INFO:  NAT detected: ME PEER
2014-02-01 20:10:12: [rv220w][IKE] INFO:  Floating ports for NAT-T with peer 99.101.94.86[4500]
2014-02-01 20:10:12: [rv220w][IKE] INFO:  ISAKMP-SA established for 192.168.0.10[4500]-99.101.94.86[4500] with spi:1e81ce312812da50:569671b6b2a1ad6a
2014-02-01 20:10:12: [rv220w][IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
after creating a new profile for the air card connection with name loveit00 of ip from air card
166.142.243.242 I still cannot connect
I can only connect using the name happy00 ip from my wifi 192.168.0,192 but shows on log as ip 99.101.94.86ip addess seen on the routers vpn connecion page.
Even stranger now after activating the vpn connection over the pptp whiles the quickvpn connection is active. I can now also access all the computers and files in my network.
however I could not sustain the vpn and quickvpn connection to access both 10.0.0.2 and 10.0.0.128 at the same time the pptp vpn connection to 10.0.0.2 took over and killed the quickvpn connection to 10.0.0.128 and I got the remote gateway no responding do you want to wait a few times and answered yes then I closed the pptp vpn to 10.0.0.2 the quickvpn came right back without restarting quickvpn.  I am currently testing toggling back and forth
what other info if any can i supply to get to the bottom of this?
Jared,
You should edit the hosts file on the Windows 8.1 PC, not the UNIX server.
10.0.1.100     UNIX server (Use the actual LAN IP of your server)
10.0.1.101     Printer
10.0.1.102     User PC
10.0.1.103     IP Camera
10.0.1.104     NAS
Now if you have a VPN connection and you ping 'NAS', your PC will look at the hosts file to figure out what you mean by 'NAS'. It will discover that 'NAS' is at 10.0.1.104 and it will ping that address. The same goes for accessing shares, etc.
Do not add firewall rules in the router for ICMP, that is not necessary. QuickVPN traffic is not filtered by the firewall. The ICMP rule that I created was in Windows 8 firewall. Windows Firewall-> Advanced Settings. Look for Inbound Rules in the upper left. Select it and click 'New Rule' in the upper right.
Rule Type: Custom
Program: All programs
Protocol and ports: ICMPv4
Scope: Any IP address
Action: Allow the connection
Profile: All?
Name: Whatever you like
If I recall correctly I created the same rule for Inbound and Outbound traffic in the Windows firewall and then I was able to connect every time. I have read in the forums that some users did not create the rules and they were able to connect, so I recommend that you experiment. Also, you may wish to make the rule more restrictive (Allow only certain IPs for example). I was just doing a quick test to see if I could make it work, I didn't spend a lot of time thinking about using it in a real world scenario.
I hope this is helpful. Please reply if you have further questions.
- Marty
SamirD
Level 5
Level 5
By the nature of the operating system, you will have two IP addresses.  The only way around this is to get another rv220w wherever you are and configure a site-to-site vpn.  Then your computer IP address will remain the same and be only one.
The other solution would be to use another computer and share that Internet connect with the computer with the software on it.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
Since my field computers use aircards. Router to router set up is not an option for me.
I am now moving on to other suggested solutions to this problem.
I no longer plan to update this thread unless by some luck I stumble upon the solution while trying other things.
thanks for you time all.
