Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
1293
Highlighted
Beginner
RV220W Printer Sharing Across VLANs
We have 2 VLANs configured to keep 2 groups of PCs apart. Is it possible to allow both VLANs to access the same printer without allowing other traffic between these VLANs ?
Any advice would be much appreciated.
3 REPLIES 3
Highlighted
Enthusiast
You should be able to yes, when you setup the printer use the IP address as its printer port and it should work fine.
Regards Simon
Highlighted
Thanks for the reply Simon.
Should I place the printer in a third VLAN (as opposed to one of the exclusive VLANs containing the PCs)? If so, will it be enough to enable"Inter VLAN Routing" on this third 3rd VLAN only?
Highlighted
yes you can do that if you want. i did setup my home lan that way.
Regards Simon
