RV220W Printer Sharing Across VLANs
indizas_cisco
Beginner
Beginner
We have 2 VLANs configured to keep 2 groups of PCs apart. Is it possible to allow both VLANs to access the same printer without allowing other traffic between these VLANs ?
Any advice would be much appreciated.
linksysinfo
Enthusiast
Enthusiast
You should be able to yes, when you setup the printer use the IP address as its printer port and it should work fine.
Regards Simon
Thanks for the reply Simon.
Should I place the printer in a third VLAN (as opposed to one of the exclusive VLANs containing the PCs)? If so, will it be enough to enable"Inter VLAN Routing" on this third 3rd VLAN only?
yes you can do that if you want. i did setup my home lan that way.
Regards Simon
Recognize Your Peers
