RV220w reboot
atisaatisa
Hello My router RV220W reboot everyday
Firmware Version
1.0.4.17
I re-install last firmware, restore the factory settings and re-config.
Any Ideas?
I have a lot of warning.
Mon Aug  5 09:01:47 2013(CEST) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Mon Aug  5 09:01:52 2013(CEST) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Mon Aug  5 09:01:52 2013(CEST) [rv220w][Kernel][KERNEL] printk: 1 messages suppressed.
Mon Aug  5 09:01:52 2013(CEST) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Aug  5 09:01:52 2013(CEST) [rv220w][Kernel][KERNEL] printk: 10 messages suppressed.
Mon Aug  5 09:01:53 2013(CEST) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Mon Aug  5 09:01:53 2013(CEST) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Aug  5 09:01:58 2013(CEST) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Mon Aug  5 09:01:58 2013(CEST) [rv220w][Kernel][KERNEL] printk: 10 messages suppressed.
Mon Aug  5 09:01:58 2013(CEST) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Mon Aug  5 09:02:03 2013(CEST) [rv220w][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Mon Aug  5 09:02:03 2013(CEST) [rv220w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
If I active wireless, I have error message
Mon Aug  5 09:05:49 2013(CEST) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 1 failed. status=-1
Mon Aug  5 09:05:49 2013(CEST) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=1
jeffrrod
Level 4
Level 4
Dear JF,
Thank you for reaching Small Business Support Community.
After upgrading the the latest firmware, reset to factory defaults and reconfigure, and based on the Kernell error, I think it is a hardware failure so my advice is to confirm and proceed about it with the Small Business Support Center directly;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please do not hesitate to reach me back if there is anything I may assist you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
trgood
Hi JF,
Do any new issues (crashes, slowness, no network connectivity) occur in correspondance with these error message?  Also, were there any changes when these issues started occuring?  Let me know, if you have any questions!
-Trent Good
** Please rate useful posts! **
-Trent Good ** Please rate useful posts! **
here is the log from this morning.
The Wireless is disable.
I still have a lot of error messages ...
I think  the router doesn't reboot when I disable the Wireless.
Thank you
Mon Aug 12 07:31:10 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:33:45 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:33:55 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:34:00 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:34:15 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:34:20 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:35:50 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:36:20 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:43:55 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:45:50 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:47:45 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:49:30 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:52:00 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:55:25 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:55:45 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:59:25 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:03:55 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:06:15 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:06:50 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:07:30 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:09:15 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:11:11 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:12:36 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:14:26 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:15:26 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:17:56 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:22:51 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:25:51 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:26:41 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:28:16 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:28:26 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:28:41 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:30:01 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:31:11 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:38:36 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:38:41 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:39:46 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:41:21 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:45:11 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:46:56 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:47:46 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:48:11 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:48:46 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 08:58:46 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:02:11 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:02:12 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:02:32 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:05:22 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:07:07 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:11:17 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:14:32 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:16:12 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:16:22 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:16:32 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:17:02 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:18:17 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 09:18:47 2013(GMT+0100) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Aug 12 07:33:50 2013(GMT+0100) [rv220w][Local0-wireless][UDOT11] wpaAuthRecvPTKMsg2: mic check failed
Mon Aug 12 07:33:51 2013(GMT+0100) [rv220w][Local0-wireless][UDOT11] wpaAuthRecvPTKMsg2: mic check failed
Mon Aug 12 07:33:53 2013(GMT+0100) [rv220w][Local0-wireless][UDOT11] wpaAuthRecvPTKMsg2: mic check failed
Mon Aug 12 07:33:54 2013(GMT+0100) [rv220w][Local0-wireless][UDOT11] wpaAuthRecvPTKMsg2: mic check failed
Mon Aug 12 07:34:14 2013(GMT+0100) [rv220w][Local0-wireless][UDOT11] wpaAuthRecvPTKMsg2: mic check failed
Mon Aug 12 07:34:15 2013(GMT+0100) [rv220w][Local0-wireless][UDOT11] wpaAuthRecvPTKMsg2: mic check failed
Mon Aug 12 07:34:16 2013(GMT+0100) [rv220w][Local0-wireless][UDOT11] wpaAuthRecvPTKMsg2: mic check failed
Mon Aug 12 07:34:17 2013(GMT+0100) [rv220w][Local0-wireless][UDOT11] wpaAuthRecvPTKMsg2: mic check failed
Mon Aug 12 07:34:18 2013(GMT+0100) [rv220w][Local0-wireless][UDOT11] wpaAuthRecvPTKMsg2: mic check failed
Mon Aug 12 07:34:19 2013(GMT+0100) [rv220w][Local0-wireless][UDOT11] wpaAuthRecvPTKMsg2: mic check failed
