1160
Highlighted
Beginner
RV220W Remote PPTP VPN connection fails
I'm having problems connecting to my RV220W using PPTP. The first time I set up PPTP on the box, everything worked just fine. Now, however, PPTP just won't work. No matter how I try to tweak various settings on the router, the connection fails. I have tried connecting with Windows 7, Android and OSX with no success.
The router came with version 1.0.1.0, and I have tried downgrading to 1.0.0.26 and upgrading to 1.0.3.5, but alas, I can't seem to make PPTP work again.
Is this a known issue with a workaround, or do I need to shop around for a replacement?
Sincerely,
Tobias
1 REPLY 1
Highlighted
Enthusiast
Hello Tobias,
Can you tell me the error code you are getting when you try to connect and it fails?
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
