Get the latest Cisco news in this February issue of the Cisco Small Business Monthly Newsletter
946
Highlighted
Beginner
RV220W - Static Route
Hello Cisco People.
I am using my Cisco RV220W as primary gateway/router on my LAN but has recently added a secondary gateway/router (4G Mobile Broadband Router).
Is it somehow possible, via RV220W static routing, to route all traffic for a specific client on the LAN, say 192.168.1.100 to always access the internet via the secondary router ?
It is only one specific client which should always route via the secondary router, all the rest of the clients on the LAN should use the primary router.
Facts:
Primary Gateway/Router (DHCP Server): 192.168.1.1
Secondary Gateway/Router (NO DHCP Server): 192.168.11.1
Subnet Both: 255.255.255.0
RV220W IPV4 Routing Table (Default):
Kernel IP routing table
Destination      Gateway      Genmask      Metric  Ref      Use      Interface      Type          Flags
127.0.0.1      127.0.0.1      255.255.255.255 1      0      0      lo          Static      UP,Gateway,Host
192.168.1.0      0.0.0.0      255.255.255.0      0      0      0      bdg1          Dynamic      UP
192.168.1.0      192.168.1.1      255.255.255.0      1      0      0      bdg1          Dynamic      UP,Gateway
192.168.11.0      0.0.0.0      255.255.255.0      0      0      0      eth1          Static      UP
192.168.11.0      192.168.11.142  255.255.255.0      1      0      0      eth1          Static      UP,Gateway
0.0.0.0      192.168.11.1      0.0.0.0      0      0      0      eth1          Dynamic      UP,Gateway
I am kinda noobish on this Iptables thing, used to GUI - but GUI can not help me this time, hope a friendly sould out there could help me instead.
Any help is appreciated,
Many Thanks !
Martin B.
Everyone's tags (4)
1 REPLY 1
Highlighted
Rising star
Martin,
It is the Default Gateway of the PC that determines how it reaches the internet. A simple solution is to configure the PC with a static IP as follows:
IP Address: 192.168.11.100
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.11.1
Primary DNS: 192.168.11.1
Secondary DNS: 8.8.8.8 (You can use ISP DNS if you like)
This will force the PC to go to 192.168.11.1 for all internet bound traffic
Give the PC a second IP address:
IP Address: 192.168.1.100
Default Gateway: NONE
This will allow the PC to have access to the RV220W LAN 192.168.1.0/24
- Marty
