RV220W Syslog Summary, ERROR and WARNING
hknberg
Hi.
Firmware Version: 1.0.4.17
I have some warnings and errors. And wondering if someone can explain if they are dangerous or can be viewed and deleted?
Syslog Summary:
Emergency:     0
Alert:               0
Critical:            0
Error:               19
Warning:          105
ERROR:
Sun Mar  3 08:37:15 2013(GMT) [RT][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 9 dot11STA 1 failed. status=-1
Sun Mar  3 08:37:15 2013(GMT) [RT][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=1
Sun Mar  3 08:37:52 2013(GMT) [RT][System][PLATFORM] IP:       XXX.XXX.XXX.XXX
Sun Mar  3 08:37:52 2013(GMT) [RT][System][PLATFORM] BCAST:    XXX.XXX.XXX.XXX
Sun Mar  3 08:37:52 2013(GMT) [RT][System][PLATFORM] SUBNET:   255.255.255.0
Sun Mar  3 08:37:52 2013(GMT) [RT][System][PLATFORM] GW:       95.34.60.1
Sun Mar  3 08:37:52 2013(GMT) [RT][System][PLATFORM] DNS1:     193.213.112.4
Sun Mar  3 08:37:52 2013(GMT) [RT][System][PLATFORM] DNS2:     130.67.15.198
Sun Mar  3 08:37:52 2013(GMT) [RT][System][PLATFORM] Interface:eth1
Sun Mar  3 08:40:07 2013(GMT) [RT][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 5 failed. status=-1
Sun Mar  3 08:40:07 2013(GMT) [RT][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=5
Sun Mar  3 08:40:07 2013(GMT) [RT][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 9 dot11STA 5 failed. status=-1
Sun Mar  3 08:40:08 2013(GMT) [RT][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 5 failed. status=-1
Sun Mar  3 08:40:08 2013(GMT) [RT][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=5
Sun Mar  3 08:43:25 2013(GMT) [RT][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 9 dot11STA 5 failed. status=-1
Sun Mar  3 08:43:25 2013(GMT) [RT][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=5
Sun Mar  3 08:45:19 2013(GMT) [RT][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 5 failed. status=-1
Sun Mar  3 08:45:19 2013(GMT) [RT][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=5
2011-01-01 00:00:42: [RT][IKE] INFO:  IKE started
WARNING:
Sun Mar  3 07:11:02 2013(GMT) [RT][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sun Mar  3 07:56:27 2013(GMT) [RT][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Sun Mar  3 07:56:27 2013(GMT) [RT][Kernel][KERNEL] printk: 22 messages suppressed.
Sun Mar  3 07:56:27 2013(GMT) [RT][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Sun Mar  3 08:11:02 2013(GMT) [RT][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sun Mar  3 08:40:07 2013(GMT) [RT][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sun Mar  3 08:45:22 2013(GMT) [RT][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sun Mar  3 08:48:52 2013(GMT) [RT][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Sun Mar  3 08:48:52 2013(GMT) [RT][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Sun Mar  3 08:56:12 2013(GMT) [RT][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Sun Mar  3 08:56:12 2013(GMT) [RT][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Sun Mar  3 08:56:13 2013(GMT) [RT][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Sun Mar  3 08:56:13 2013(GMT) [RT][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Sun Mar  3 08:56:28 2013(GMT) [RT][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Sun Mar  3 08:56:28 2013(GMT) [RT][Kernel][KERNEL] printk: 8 messages suppressed.
Sun Mar  3 08:56:28 2013(GMT) [RT][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Sun Mar  3 08:56:33 2013(GMT) [RT][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Sun Mar  3 08:56:33 2013(GMT) [RT][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Sun Mar  3 08:56:34 2013(GMT) [RT][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Sun Mar  3 08:56:34 2013(GMT) [RT][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Sun Mar  3 08:56:34 2013(GMT) [RT][Kernel][KERNEL] printk: 2 messages suppressed.
Sun Mar  3 08:56:34 2013(GMT) [RT][Kernel][KERNEL] printk: 1 messages suppressed.
Sun Mar  3 09:04:34 2013(GMT) [RT][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Sun Mar  3 09:04:34 2013(GMT) [RT][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Sun Mar  3 09:04:49 2013(GMT) [RT][Kernel][KERNEL] WARNING:cvmx_ptr_to_phys() passed a NULL pointer
Sun Mar  3 09:04:49 2013(GMT) [RT][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
Sun Mar  3 09:11:04 2013(GMT) [RT][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Thank you for your help.
Regards Håkon
jonatrod
Level 7
Level 7
Thank you for using our forum, my name is Johnnatan I am part of the Small business Support community. I apologize for this inconvenience you are having, also I am sorry if I can´t give you a complete information regarding this kind of logs, multiple of these are application Port-based Network Access Control, also some of these error are regarding this software, in charge to control all the traffic to give you a extra security. All these logs are security reports which were accessed through wireless.
To answer your question, those are security tracking of all alerts that software gave you, in this case I advise you to keep with this information. I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
"I advise you to keep with this information."
What kind of answer is that? Could you provide something a little more useful, as I to am having the same issues. Is this a wireless configuration issue?
Ron Sullivan
Hi Hakon, thank you for using our forum, the log message is saying that the router is trying to match or allocate memory for a process, but the memory is either full, or it can't find anything to match. Could you please reach out to our Small Business Support Center and open a Service Request to address this issue? One of our Engineers may be able to work with you and diagnose the root cause. You can find the appropriate contact information for SBSC in the below link.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Greetings,
Luis Arias.
