RV220w VPN PPTP On LAN Interface
tvdm12000
I have a situation where I need to provide VPN PPTP access to remote users. The setup includes a Cisco 861 router connecting to and controlling access to the WAN. The RV220w is on the LAN side and is connected to the 861 via the LAN interface. I don't have access to the 861 as it is supported by another party so a VLAN may be a pain to have set up.
My question, is it possible to have the RV220w respond to port 1723 on its LAN interface instead of the usual WAN interface? It has been suggested I need to look into the router's default gateway to use a LAN address in its routing table...
Thank you
0 Replies 0
