07-03-2013 07:33 AM
Is there any way to disable the management of the router from a wireless connection? My point is that anyone (being a wireless user or someone else) could hack the password from outside the building and modify the router settings through a wireless connection. I know that the lower Linksys range provides this feature, but I can't find it for the RV220W. I actually want to make sure that only an Ethernet device can manage the router. That will add to the security as I currently have full control on those PCs.
Solved! Go to Solution.
07-03-2013 11:20 AM
Daniel,
The RV220W does not have a feature to block web administration for wireless users as some of our legacy products did. Please be sure to use a strong password.
Edit: You can add a second VLAN for wireless users and disable Device Management under VLAN Membership Table.
- Marty
07-03-2013 11:20 AM
Daniel,
- Marty
07-03-2013 11:22 AM
Thanks Marty... It would be great to add this feature in a future firmware relase...
Daniel
