07-24-2012 04:56 PM
I have a RV220W operating in 2.4GHz N-only mode. Channel bandwidth is set to 20MHz, channel to 6 (a site survey shows that channel as completely clear), WPA2/AES. I am connected to a TrendNet wireless bridge. The admin page for that wireless bridge shows a link quality of 100% with a signal strength of 71%. If I select a higher channel (11), the signal strength drops to 51%.
I have a Windows 7 PC connected to the Trendnet bridge and a Windows 7 server connected to the RV220W, both via a 1Gbps LAN port. When I transfer a file from the server to the PC or vice versa, I get a lowsy 2MBps (~20Mbps) transfer rate. That seems awfully slow. I tried channel bonding from 20 to 40 MHz, but that did not help. What could I do to improve this??
07-24-2012 05:36 PM
Hello Awesterink,
Wireless is extremely subjective. To approach this, I would to break everything down starting at the basics.
Try to narrow down the break down as much as possible. For each change, test to see the result. Once you identify where things are bogging down, then we have a direction to go.
07-25-2012 09:01 AM
Your stepped approach makes perfect sense, I'll give that a shot. Thanks for your reply.
