I have enabled Hardware DMZ
So LAN 8 should now be the DMZ
I enabled the Hardware DMZ with a single IP address
But when I goto http://ip.address I get the login for the router and NOT the PC connected to LAN 8?
How do you set up a simple DMZ on the RV260 so I can access the PC on the DMZ, but NOT the router and NOT the LAN (ports 1-7) ??
Thanks in advance
- Check if this document can help you :
M.
