03-24-2020 09:18 AM
I bought a RV260 for VPN connections recently, firmware 1.0.00.17, and I try to config VPN PPTP since 3 days, as I often did it before. Even the easiest way to connect with VPN PPTP is not possible, because of the following error.
2020-Mar-24, 16:55:32 AZOT | error | vpn | pptp: RADIUS: Can't read config file /etc/radiusclient/radiusclient.conf |
2020-Mar-24, 16:55:32 AZOT | error | vpn | pptp: rc_read_config: can't open /etc/radiusclient/radiusclient.conf: No such file or directory |
I have no RADIUS configured (NO Remote Authentication Service)!
The problem seams to be well known with other routers, however unsolved!
Other VPNs e.g. IKE2 does not work either.
Does anyone know a solution for this problem?
Thanks for any help!
Serial Number | DNI2314A22H |
System Up Time | 0 days 4 hours 14 minutes 55 sec |
Current Time | 2020-Mar-24, 17:05:21 CET |
PID VID | RV260-K9 V01 |
Firmware Version | 1.0.00.17 |
Firmware MD5 Checksum | 7e7f47aca77c363a0b440ff3ffe5f6ae |
Locale | English |
Language Version | 1.0.0.0 |
Language MD5 Checksum | d901cc97ae6a606564195bb34fc2d4d2 |
03-24-2020 10:19 AM
i see some issues around same- replied to the user with information, but user never come back it was fixed or not.
https://community.cisco.com/t5/small-business-routers/rv260-and-pptp-fails/m-p/4034016
03-24-2020 11:48 AM
Thanks for your reply, but I red this posts already and they do not have a solution.
PAP (without encryption!) does not work either, that's the log:
2020-Mar-24, 19:44:40 AZOT | notice | vpn | pptp: Connection terminated. |
2020-Mar-24, 19:44:40 AZOT | warning | vpn | pptp: peer refused to authenticate: terminating link |
2020-Mar-24, 19:44:40 AZOT | error | vpn | pptpd: CTRL: Ignored a SET LINK INFO packet with real ACCMs! |
Besides VPN without encrypted seems to defeat the purpose.
I tried it with different Windows systems, as well as with ubuntu. It seems to be a severe bug of quite a lot of this small business products.
I only bought this RV260 for VPN and now I can only use it as a firewall and switch. I probably will send it back soon.
However I still hope, that there is a solution.
08-25-2020 05:52 AM
PAP works as per below link. Disable MPPE encryption on router, PPTP server as well.
