07-20-2013 12:57 PM
I haven't been able to track down a manual yet for the RV320. Has anyone successfully setup the 3g/4g USB option? If you have, would you let me know what you did.
The first thing they ask for is a PIN#, I've never used a PIN to access my VZW MiFi, so I'm not sure what they're looking for.
Thanks.
10-20-2019 10:57 AM
Based on the network IP address we had, we changed Device IP address of CISCO router (for example, our network IP
address range is 192.168.0.1 – 192.168.0.255, so in
DHCP setup of CISCO router –
Change Device IP address to 192.168.0.1 with subnet mask 255.255.255.0
DHCP mode – DHCP server
Range start 192.168.0.2 Range End 192.168.0.149 or as you need
SAVE the settings
In Multiple Subnet Table, keep IP address 192.168.0.1 and delete the other 2 addresses
SAVE the settings
Select Smart Link Backup and select WAN1 or WAN2 which you want to be your primary
connection (obviously the ACT Fibernet connected to WAN2, in our case)
SAVE the settings
WAN1 Connected (Inactive) and no IPv4 details of WAN1,
WAN2 Connected and IPv4 details of WAN2 would be filled
Now internet will be working with WAN2 ISP network.
