Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1102
arkiados
Beginner
RV320 Client to Gateway Group VPN Failure
I am trying to access my RV320 from Android and Windows but receive a failure.
RV320
2018-10-30, 19:49:17	Kernel	kernel: wrong ip[0],not_list[0]
2018-10-30, 19:49:17	Kernel	kernel: upnp idx=153, ip=192.168.1.141, eport=7048, iport=7048
2018-10-30, 19:49:17	Kernel	kernel: upnp idx=142, ip=192.168.1.141, eport=7048, iport=7048
2018-10-30, 19:49:17	Kernel	kernel: upnp idx=233, ip=192.168.1.132, eport=2776, iport=2776
2018-10-30, 19:49:17	Kernel	kernel: upnp idx=222, ip=192.168.1.132, eport=2776, iport=2776
2018-10-30, 19:49:17	ALLOW	UDP 192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500 on eth0
2018-10-30, 19:49:17	VPN Log	[grpips0][3] 192.168.1.0/24=== ...192.168.1.139===? #15: [Tunnel Authorize Fail] peer proposed key length not enabled for this connection. Attribute OAKLEY_KEY_LENGTH
2018-10-30, 19:49:17	Kernel	last message repeated 7 times
2018-10-30, 19:49:17	VPN Log	[grpips0][3] 192.168.1.0/24=== ...192.168.1.139===? #15: [Tunnel Established] ISAKMP SA established
2018-10-30, 19:49:17	VPN Log	[grpips0][3] 192.168.1.0/24=== ...192.168.1.139===?: [Tunnel Disconnected] grpips0 instance with peer 192.168.1.139 {isakmp=#0/ipsec=#0}
Android (has nice verbose logging)
INFO: 19:49:18 Routing instance global initialized with id 0 mapped to inode 18446744073709551615
INFO: 19:49:18 Routing instance global activated.
INFO: 19:49:18 Added new interface: 2
INFO: 19:49:18  2: `dummy0' [Routing instance=0:global MTU=1500]
INFO: 19:49:18     fe80::b41f:b1cf:fec5:f1dd/64
INFO: 19:49:18 Added new interface: 4
INFO: 19:49:18  4: `rmnet_ipa0' [Routing instance=0:global MTU=2000]
INFO: 19:49:18 Added new interface: 5
INFO: 19:49:18  5: `p2p0' [Routing instance=0:global MTU=1500]
INFO: 19:49:18     fe80::60f1:89ff:fe8e:a9c1/64
INFO: 19:49:18 Added new interface: 6
INFO: 19:49:18  6: `wlan0' [Routing instance=0:global MTU=1500]
INFO: 19:49:18     fe80::62f1:89ff:fe7e:a9c0/64
INFO: 19:49:18     fc00::62f1:89ff:fe7e:a9c0/64
INFO: 19:49:18     fc00::8c43:7f14:f599:15d/64
INFO: 19:49:18     192.168.1.139/24
INFO: 19:49:18 Added new interface: 7
INFO: 19:49:18  7: `rmnet_data0' [Routing instance=0:global MTU=1428]
INFO: 19:49:18     fe80::af00:c88:9f83:994/64
INFO: 19:49:18     2600:1004:1117:d581:2b04:5063:8a2e:2132/64
INFO: 19:49:18 Added new interface: 8
INFO: 19:49:18  8: `rmnet_data1' [Routing instance=0:global MTU=1428]
INFO: 19:49:18     fe80::da44:c48:923a:2991/64
INFO: 19:49:18     2600:1004:b103:791:9ded:b15c:adb2:1dbe/64
INFO: 19:49:18     100.91.35.22/30
INFO: 19:49:18 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): len= 1040, mID=00000000, HDR, SA, KE, Nonce, ID, Vid, Vid, Vid, Vid, Vid, Vid
INFO: 19:49:18 IKEv1 packet R(192.168.1.139:38364 <- xxx.xxx.xxx.xxx:500): len=  448, mID=00000000, HDR, SA, KE, Nonce, ID, Vid, PRV, PRV, HASH, Vid, Vid
INFO: 19:49:18 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): len=  108, mID=00000000, HDR, HASH, PRV, PRV
INFO: 19:49:18
INFO: 19:49:18 IKEv1 SA [Initiator, Aggressive] negotiation completed:
INFO: 19:49:18
INFO: 19:49:18   Local Authentication Method  : Pre-shared key
INFO: 19:49:18   Remote Authentication Method : Pre-shared key
INFO: 19:49:18   IKE algorithms : aes256-cbc, hmac-sha1, hmac-sha1-96
INFO: 19:49:18   Diffie-Hellman : group 5 (dh-modp-1536)
INFO: 19:49:18
INFO: 19:49:18   Routing instance 0:global
INFO: 19:49:18   Local IKE peer  192.168.1.139:38364 ID contoso.com
INFO: 19:49:18   Remote IKE peer xxx.xxx.xxx.xxx:500 ID xxx.xxx.xxx.xxx
INFO: 19:49:18   Initiator SPI 6001f217 e61428a8Responder SPI e1a85456 735002c3
INFO: 19:49:18   Local Lifetime: 86400 seconds
INFO: 19:49:18 IKE SA negotiations: 9 done, 7 successful, 2 failed
INFO: 19:49:18 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): len=  108, mID=7db019eb, HDR, HASH, ATTR
INFO: 19:49:19 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): mID=7db019eb (retransmit count=1)
INFO: 19:49:21 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): mID=7db019eb (retransmit count=2)
INFO: 19:49:25 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): mID=7db019eb (retransmit count=3)
INFO: 19:49:33 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): mID=7db019eb (retransmit count=4)
INFO: 19:49:43 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): mID=7db019eb (retransmit count=5)
INFO: 19:52:17 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): mID=7db019eb (retransmit count=6)
INFO: 19:58:27 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): mID=7db019eb (retransmit count=7)
INFO: 19:58:37 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): mID=7db019eb (retransmit count=8)
INFO: 19:58:39 Phase-I negotiation failed
INFO: 19:58:39   Message: SA unusable (65553)
INFO: 19:58:39 IKEv1 packet S(192.168.1.139:38364 -> xxx.xxx.xxx.xxx:500): len=   92, mID=83d884ff, HDR, HASH, DEL
INFO: 19:58:39
INFO: 19:58:39 IKE SA destroyed:
INFO: 19:58:39   Initiator SPI 6001f217 e61428a8 Responder SPI e1a85456 735002c3
INFO: 20:01:28 Deleted interface: 8
INFO: 20:01:28  8: `rmnet_data1' [Routing instance=0:global MTU=1428]
INFO: 20:01:28     fe80::da44:c48:923a:2991/64
INFO: 20:01:28     2600:1004:b103:791:9ded:b15c:adb2:1dbe/64
INFO: 20:01:28     100.91.35.22/30
INFO: 20:01:28 Deleted interface: 7
INFO: 20:01:28  7: `rmnet_data0' [Routing instance=0:global MTU=1428]
INFO: 20:01:28     fe80::af00:c88:9f83:994/64
INFO: 20:01:28     2600:1004:1117:d581:2b04:5063:8a2e:2132/64
INFO: 20:01:28 Deleted interface: 6
INFO: 20:01:28  6: `wlan0' [Routing instance=0:global MTU=1500]
INFO: 20:01:28     fe80::62f1:89ff:fe7e:a9c0/64
INFO: 20:01:28     fc00::62f1:89ff:fe7e:a9c0/64
INFO: 20:01:28     fc00::8c43:7f14:f599:15d/64
INFO: 20:01:28     192.168.1.139/24
INFO: 20:01:28 Deleted interface: 5
INFO: 20:01:28  5: `p2p0' [Routing instance=0:global MTU=1500]
INFO: 20:01:28     fe80::60f1:89ff:fe8e:a9c1/64
INFO: 20:01:28 Deleted interface: 4
INFO: 20:01:28  4: `rmnet_ipa0' [Routing instance=0:global MTU=2000]
INFO: 20:01:28 Deleted interface: 2
INFO: 20:01:28  2: `dummy0' [Routing instance=0:global MTU=1500]
INFO: 20:01:28     fe80::b41f:b1cf:fec5:f1dd/64
INFO: 20:01:28 Routing instance global deactivated.
INFO: 20:01:28 Routing instance global uninitialized.
0 REPLIES 0
