11-21-2022 11:51 AM
I am trying to configure a rv320 dual wan and I am having issues between a cable modem and the router. I am able to get out using obtain an ip but I cannot get to any ports when I try to come in from the outside via the cable modem to the router and to the final destination. I just know enough to screw things up, so any help in English would be greatly appreciated.
Solved! Go to Solution.
11-21-2022 11:37 PM
how is your config look like - when you mentioned Dual wan, do you have Dual ISP connection or single one :
check below document for portfowarding :
note if the ISP blocking the ports then it wont even reach your router, so check the logs of RV is the packets reaching the router when the connection intiated from outside.
11-21-2022 11:37 PM
11-22-2022 07:49 AM
11-22-2022 08:49 AM
Do you see any logs on device ? have you checked with ISP ?
11-22-2022 08:55 AM
11-22-2022 09:06 AM
logs you see on the router, do you see any port forward logs (not on IIS)
anothing do not expose port 80 that is security risk.
