4118
Highlighted
Beginner
RV320 firmware 1.4.2.22 refuses to display login page with Safari, Chrome, Firefox and Edge
We updated successfully an RV320 to 1.4.2.22 via a browser (Chrome) and immediately lost the ability to reach the log-in page from a browser.  We tried a factory reset and all the above browsers without a good result. Either there is no response at all or we get a certificate/dangerous site warning and the log-in page won't display even when clicking advance.  I then set up a tftp server (Tftpd64 on Windows 7) and successfully downgraded to (the insecure) 1.3.2.03 version.  It works perfectly.
We repeated the upgrade using tftpd64 to 1.4.2.22 after a fresh firmware download from Cisco and the upgrade proceeded without errors but has the same problem with no ability to reach the log-in page from any browser. Now we are back on a functioning insecure 1.3.2.03.
After the upgrade to 1.4.2.22, we can ping 192.168.1.1 successfully.  We just have no way to reach the log-in page from any browser!
This looks like a firmware bug.
Any ideas?
13 REPLIES 13
Highlighted
Beginner
To eat my own dog food, I enabled SSH login in the working version 1.3.x.xx, ran the 1.4.2.22 update from the tftd server and found (as usual) that login GUI page was dead.  However, I could now SSH in and a check of the 1.4.2.22 settings showed the unit date was set to 6-6-2024(!) for some reason.  I reset the date and time correctly via SSH and rebooted and the GUI came good—and I was able to complete setup of the VPN as normal.
My guess is that that the date error was somehow blocking the certificate check and hanging the GUI.   I hope this description helps If this happens to others when running the 1.4.2.22 update.
Highlighted
Beginner
I am having the same issue with an RV320.  I checked the login page HTML that is coming back, and there is a missing JS reference to "language.js" which causes the page to not render and therefore I cannot login to it.
I also cannot get SSH into it, because my password will not work
Highlighted
Set back to factory defaults (cisco/cisco), setup Tftpd server (https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb4890-workaround-for-inaccessibility-of-gui-after-firmware-version.html ) to flash new firmware to it using Tftpd64 application (free on net), log-in to GUI and set SSH access to ON, and then setup your settings again.
I’m using FF 68.1 to access without problems now,
Highlighted
Beginner
I have a similar issue.  I updated the firmware on my RV320 a few weeks ago to 1.4.2.22 as I was getting random network latency and the router began becoming unresponsive.  I also have a Linksys EA7500 as a wireless AP on my network.  Yesterday, BOTH the RV320 and EA7500 became completely unresponsive, and unable to be accessed by a web interface, and unable to be reset to default config.
I imagine I will have to tftp into it and roll back, but just thought it was kinda strange for both units to brick at the same time?  Any thoughts?
Note:  I am not sure, but it is possible I was being UDP DDoSed for a while (logs would indicate that multipul random UDP ports were being probed, by a huge variety of hundreds of IP addresses, all at the same time log)...  So maybe this was done on purpose?  Also note, the MAC of the Cisco RV320 is displaying 00:DE:AD:20:75:02  >.>
Highlighted
I managed to solve this issue by proxy the cisco access throw a nginx server. The script language.js was not found so i find a demo portal offered by Cisco from where i proxied the file.
The config for nginx can be found bellow:
server {
listen 20080;
server_name localhost;
location / {
# for https access
proxy_pass https://router_Ip:router_port;
# for http access
#proxy_pass http://router_Ip:router_port;
location /language.js {
proxy_pass https://www.cisco.com/assets/sol/sb/RV320_Emulators/RV320_Emulator_v1.1.0.09/language.js;
After this i have accessed the nginx on port 20080 and try to login by changing the language to french which triggered the access to become functional again.
I would say a nice solution to obtain access to the router and perform backup.
Hope it helps others.
Enjoy,
Daniel
Highlighted
I have fixed it with pure javascript.
Since the dom is just invisible due to missing "language.js" file - some do elements have incorrect state.
So, the easy way is to "set programmatically" the language combobox value AND execute POST request to the sever (rv320)
Here is the steps:
1. Open you routers login page
2. Open dev tools in your browser -> select Console and be ready to type 3 commands.
[I got the html source from page and found this code in it, Software Engineers may find this here: "function LanguageChange()"]
3. Print and hit enter: document.form_contents.changelanguage.value = "ENGLISH"
4. Print and hit enter: document.form_contents.submitStatus.value=1
5. Print and hit enter: document.form_contents.submit()
6. POST request must be sent to webserver of rv320 and page reload must occur.
Now your router is usable.
In case of any mistakes pls feel free to contact me by email: GothicSecret@gmail.com
Thanks, Max.
Highlighted
I have four routers (one RV082, three RV325s) with the same issue.  For one RV325, using the browser Console worked.  For the RV082, a simple reboot got my sign-on screen to display and I have full access again.  For the other two RV325s, I need to do a reboot, but they are remotely located and I will get reboots done first, then hopefully all will be well, or I can do the Console fix.
Thanks for posting this, it saved the day for me.
Highlighted
I have a three RV325's.  One of them has now had this issue for the third time.  Are there any suggestions for how to prevent this from happening again?
Sam
Highlighted
Hmmm. It has happened to me only once.
But I have this router less than a year for now.
I have firmware version 1.5.1.05
Does you problem with UNDEFINED block you to log in?
Highlighted
THANK YOU VERY MUCH, THIS WAS VERY HELPFUL SOLVED MY LOGIN PAGE PROBLEM AT TWO SITES
Highlighted
Hi) thank you for the feedback.
Highlighted
It works for me! Thanks a lot from Argentina!
Highlighted
Frankly, Cisco should be ASHAMED of the quality of their firmware releases since 1.13.x. They have been riddled with bugs and GUI issues through the entire 1.14 and 1.15 series. Even the latest 1.15.1.1 does not return the hardware to factory defaults when pressing the reset key for more than 10 seconds at power on. This is disgusting code quality and whoever is writing it needs to go back to CS classes.
It has got so bad that I will never buy Cisco equipment again.
