Hello All,
I have a setup like this:
VPN A <-> [Router A / LAN A] <-- G2G VPN --> [Router B / LAN B] <-> VPN B
Both routers are RV320 in gateway mode, the gateway to gateway VPN is an IPsec vpn. I use OpenVPN for both VPN A and B.
- When i log on to VPN A i can reach router A and LAN A
- When i log on to VPN B i can reach router B and LAN B.
- From LAN A i can reach LAN B, using the G2G VPN connection.
But when i log on to VPN A, i cannot reach LAN B (and the other way round)
What i would like to achieve is the possibility to reach both LANs from both VPNs. Is this possible?
Thanks in advance for your swift answer!
Best Regards, b.
