01-18-2018 07:15 AM - edited 03-21-2019 11:02 AM
I have an RV320 router updated with the latest firmware (v1.4.2.17)
The problem I have is that I'm not seeing ANY SSL settings. No SSL Certificate menu... no SSL VPN menu... no SSL VPN Enable checkbox on the Firewall/General page.
Any ideas?
01-25-2018 11:59 AM
02-09-2018 07:34 AM
I could not find it in latest firmware (v1.4.2.17)
I downgraded to v1.3.2.02 (2016-09-23, 15:17:06) and the options are now there
I researched for a while and could not find an explanation
02-09-2018 07:40 AM
Thank you TekResults.
I found I had to rollback the firmware to 1.2.1.14 as well since I needed to change the IP Range For Virtual Passage in Advanced Settings. Version 1.3.2.02 wouldn't allow me to change them.
02-09-2018 07:53 AM
In my case I lost all my settings when I did rollback.
It would be good for Cisco to outline why they removed SSL VPN in most recent firmware.
We have many Cisco ASAs deployed at client sites. We have started deploying RV320s because ASAs are end of life and lower level models do not do gigabit speeds. We have setup IPSEC VPN but with lack of support in windows 10 we need an alternative. Thought SSL VPN would work but it seems restrictive.
We have used the workarounds to maintain Cisco client on windows 10 but unfortunately it is removed when major updates of windows 10 are installed. We have used the Shrewsoft product. However it would be good to have something on windows 10 that is natively supported.
02-24-2019 05:22 PM
Any information about this? I upgraded also, and lost SSL VPN configuration.
03-03-2019 09:36 AM
Mi SSL VPN settings are missing from an RV325 router with firmware v1.4.2.19 (2018-03-30, 14:26:03) installed!
03-03-2019 09:41 AM
I went to do a firmware upgrade for the RV325 to ""RV32X_v1.4.2.20_20181224" and noticed the following interesting text tin the popup...
"To make sure firmware upgrade process smoothly, some services like DHCP will be shut down and files for OLH and SSL VPN will be removed as well. If there is any trouble during firmware upgrade, please re-download the correct firmware or reboot the system to ensure the device works normally. Are you sure you want to upgrade firmware right now?"
It does show SSL VPN will be removed. Why and how can it be put back on without downgrading firmware?
03-19-2020 07:44 AM
Did anybody ever get a real response on this? When downgrading from the latest version to the version where the SSL VPN was still available it also raised the message it would remove SSL VPN. I think it is supposed to warn that it will be disconnected due to the reboot, it is just badly worded.
Thanks, Hanno
04-14-2020 06:24 PM
Still waiting for a response on this for myself as well. I am unable to access the GUI at 192.168.1.1 due to an invalid secrity certificate.
11-11-2020 03:33 AM
RV320 - same here fw 1.5.1.11 no SSL.
11-12-2020 02:19 AM
Hello Martyzbg,
Starting with firmware release v 1.4.2.17 the SSL VPN feature is removed on RV320 and RV325 routers.
Martin
