01-02-2018 09:41 AM - edited 03-21-2019 11:02 AM
If I connect with the latest Android OpenVPN it tells me, the certificates I created with RV320 are MD5 signed. Also it tells me, that MD5 support will end April 2018.
So how else shall I create certificates for OpenVPN? The root cert uses SHA256 but the Ovpn client/server certs are created with MD5.
01-03-2018 09:39 AM - edited 01-05-2018 11:52 AM
Cisco is aware of this since i've opened a case for this problem:
CSCvf35230
01-05-2018 07:16 AM - edited 01-06-2018 03:15 AM
Thanks for your reply, but I cannot create a ticket as I don't have a service contract. Well, if they don't want my input, I will go with a different brand.
The Ubiquiti router seem to be a good alternative !
03-18-2018 02:48 PM
06-04-2018 05:03 PM
I've opened a case referring back to refrainfrombein
I'm waiting to OK to interrupt our Internet connection, I'll report back here after I've reviewed, and (if the OpenVPN certificate is updated) reconfigured and tested the OpenVPN client on iPhone.
06-04-2018 07:44 PM
Confirming with the Cisco provided beta firmware that generated OpenVPN client and server certs are now signed with SHA256, and that after updating all relevant certs I could connect with my iPhone using a newly exported OVPN file.
Will test with more clients and update as I am able.
06-05-2018 05:29 PM
Confirming I could connect using Windows and Android OpenVPN clients using certs generated by the beta provided by Cisco, which are (automatically) signed with SHA265 rather than MD5.
06-06-2018 04:06 AM
Finally! Where can I get this firmware version?
06-06-2018 11:38 AM
I opened a case and had to sign a participation form for the beta program.
It seemed to help that I mentioned the bug report # above.
07-25-2018 03:52 PM
Sorry for long delay in replying to the board. Death in the family. (Just don't want to be confused with a poster who only takes but does not give back!)
I installed the beta FW today and can connect using OpenVPN 2.4.5 on Windows 10. I can also connect from Android. I have yet to test iPhone but will since that was the device which precipitated my need for SHA over MD5.
I am happy to report that none of my configuration settings were deleted or modified during the firmware update. That said, I backed up beforehand!
I hope everyone who needs this fix gets it soon.
06-06-2018 07:52 PM
Did they mention anything about a date/timeframe for general availability?
06-07-2018 08:43 AM
Quoting the SMB Network Engineer who worked with me:
"I’m told we’re targeting a September release, although that can change. And yes, to get a copy of the beta, they would need to open a case. It would get escalated to me or someone else on my team, and we’d send the release form just like I did with you."
06-07-2018 10:11 AM
@Folgers, Thank you for your many posts on this subject. I've got three clients with RV320/325 routers whose OpenVPN setups are crippled.
None of my clients have support contracts with Cisco. I had sent them links to purchase the routers and then I set them up at their sites. Do I need (Do you have) a formal (paid) service contract to get support and open a case?
If a special support contract is not needed, could you include the link to the web page where you initiated your support case? I've spent 45 minutes in a cisco.com web page loop, even signing up for the beta program, but I'm not able to find a place to enter a case.
Last, when you mentioned "It seemed to help that I mentioned the bug report # above," I can't seem to find "refrainfrombeinglame's bug report." Got a link or a bug report #.
I realize that this is likely a case of PEBCAK -- problem exists between chair and keyboard -- but if you could help me help myself despite myself, I'd really appreciate it.
Thank you in advance.
06-07-2018 11:10 AM
I do have an active support contract, and I think (but not certain) in this circumstance one is needed to open a new case. I think it's worth a try to start the process at https://mycase.cloudapps.cisco.com/case?referring_site=support_mm and see what result you get.
The bug report mentioned is CSCvf35230
Do you have a Cisco Small Business partner that you've worked with? They may be able to open a case on your behalf...
06-07-2018 11:24 AM
Thanks. I don't work with a Cisco Small Business partner. I'll see how far I get on my own with the link you provided.
Otherwise, I'll watch from the sidelines until a public release. (Been using PiVPN as a cheap substitute. Highly recommend it.)
