RV320 Some Questions
Daniele A.
Hello to all,
I bought an RV320 and after a couple of days of testing, I have some questions:
  • Is there a way to view all the connected devices to the network (ARP table?)? I understand that the RV320's CLI has only 2 commands.
  • Is there a way to setup a L2TP/IPSEC (no PPTP) VPN and connect to it via the Windows built-in VPN client and via the Android built-in VPN client? If yes, where I can find an exaustive guide? Every article I found is not working =O
    I only managed to connect via the EasyVPN + Cisco VPN windows client but I'd like to have a more native method to connect (that, again, is not PPTP).
  • Does forwarding a port also automatically opens a that port on the firewall without having to create a rule?
Thank you for your help!
Daniele
Ami Xiao
Hi Daniele
  1. As I know, you can only view the connected devices thru few places, e.g.dhcp status, ip&mac binding,lldp and bonjour, CLI not support shows ARP table.
  2. Since windows and android built-in vpn client more like l2tp over IPsec, I don't think it can connect with rv32x, u should be use third party vpn client to do it, something like greenbow, shrewsoft...etc.
  3. You can find the currently listening port on log→processes page, seems rv32x does not open the forwarding port, probably by adding iptables rule to achieve the goal.
Regards.
Ami
Ami Xiao
Hi Daniele
Regards.
Ami
Thank you for your help Ami
