ANNOUNCEMENTS
  • New Firmware Available for the RV340 Series Router Family! posted Apr 30, 2019
This includes the RV340, RV340W, RV345, and RV345P. To learn more and get the latest Firmware version click here
  • Important Update: Cisco RV340 Series and Cisco AnyConnect Secure Mobility Client posted Nov 10, 2018
The RV340 Series supports Remote Tunnel Termination of the best-selling and easy to use Cisco AnyConnect Secure Mobility Client... read more
237
Beginner
RV320 specific websites timeout behind device
I have been using an RV320 Gigabit Dual WAN VPN Router for several years now in a simple modem->router->switch configuration, and around the start of August I began noticing a few websites began timing out when I tried to access them.
For example, I cannot reach hivelocity.net (a dedicated server host) via HTTP any longer, though I was accessing it regularly before. It responds to ICMP traffic (ping, mtr/traceroute), and using nslookup I can verify DNS is responding properly.
# ping hivelocity.net
PING hivelocity.net (66.232.99.10) 56(84) bytes of data.
64 bytes from 66-232-99-10.static.hvvc.us (66.232.99.10): icmp_seq=1 ttl=56 time=147 ms
64 bytes from 66-232-99-10.static.hvvc.us (66.232.99.10): icmp_seq=2 ttl=56 time=82.8 ms
64 bytes from 66-232-99-10.static.hvvc.us (66.232.99.10): icmp_seq=3 ttl=56 time=82.8 ms
64 bytes from 66-232-99-10.static.hvvc.us (66.232.99.10): icmp_seq=4 ttl=56 time=83.3 ms
64 bytes from 66-232-99-10.static.hvvc.us (66.232.99.10): icmp_seq=5 ttl=56 time=78.0 ms
^C
--- hivelocity.net ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4002ms
rtt min/avg/max/mdev = 78.071/94.909/147.450/26.340 ms
Testing a telnet connection to port 80
# telnet google.ca 80
Trying 172.217.3.163...
Connected to google.ca.
Escape character is '^]'.
^C
Connection closed by foreign host.
# telnet hivelocity.net 80
Trying 66.232.99.10...
^C
Additionally, when I bypass the RV320 and connect directly to the modem I'm able to connect and load sites properly. I have also upgraded the firmware to the latest version, and have attempted both power cycling and a factory reset without success.
Has anyone run into something like this before? Or have any suggestions about how to debug further?
Thank you,
Jeff
