I have an RV320 router set up with multiple VLANS. Inter VLAN routing works fine with locally connected devices. I'm trying to set up an SSL VPN client connection that can reach devices on multiple VLANS using Virtual Passage. I have Virtual Passage set for Split Tunneling. Currently, I can only reach devices on the same subnet that the Virtual Passage adapter receives an IP address from. Is there a way to get this working?
