In my quest to get load balancing with 3G/4G modems, I have come across the RV315W and RV320.
I have looked into their Documentation and Online Device Emulator:
http://www.cisco.com/assets/sol/sb/RV315W_Emulators/RV315W_Emulator_v1.01.03/index.asp.htm
http://www.cisco.com/assets/sol/sb/RV320_Emulators/RV320_Emulator_v1.0.1.01/default.htm
The RV315W can use one of its USB ports with a 3G/4G modem, and use it to load balance with the other two WAN links.
The RV320 can use both of its USB ports with a 3G/4G modem, however I'm not seeing the possibility to use them for load balancing?
Is that correct?
I am at a location with scarce internet connection, and would really like to load balance between multiple sources of 3G connectivity.
The RV320 would seem as the perfect fit, if it would do load balancing like its RV315 brother.
If not, what would you suggest?
RV315W + 3G Modem + 3G Router - utilizing one of the RV315 WAN links instead?
Thank you.
