ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
158
Highlighted
Beginner
RV320 VPN disconnect every 8-10 minutes
I set up a VPN on the RV320 router. It could be working fine for a few days. Then it happens "VPN Client: Reason 412 - The remote peer is no longer responding". At the beginning, the issue could be fixed after reboot the router. Recently, it becomes worse. The issue happened again since yesterday. Even though I rebooted it, the issue is still existing. I had upgraded the firmware to the latest 1.5.1.11. Disabled WAN2.
Can any one see this issue before, do you have any solution for this issue?
It is the first time to try to use RV320 router. Is it reliable?
3 REPLIES 3
Highlighted
Beginner
Re: RV320 VPN disconnect every 8-10 minutes
I'm seeing something similar with an RV340, which is being used as a VPN gateway. It seems that heavy VPN traffic causes the router to reset its WAN interface, which then becomes defunct and non-responsive. I first observed the issue on Friday when multiple clients started simultaneously downloading large files over VPN (heavy upstream traffic). It didn't happen before when only 1 or 2 clients were transferring files. With multiple clients it only takes a couple of minutes before the interface goes down. Is that similar to what you're seeing?
Both unplugging/replugging the WAN cable, and disabling/enabling the WAN interface fixed the issue only for the next couple of minutes. The best workaround was going to QoS -> WAN Bandwidth Management menu and lowering the router's available upstream bandwidth to 85% of our link's capacity. With this change the router has been stable for a couple of days now.
Highlighted
Beginner
My clients have two monitors, one computer uses RDP, another open the file in the file server. They might open some large files. Let me try to monitor the bandwidth as what you said.
Highlighted
Beginner
It is still not stable. vpn client works only 8-10 minutes, then can't ping the internal IP address even though the vpn client is still connected.
