03-02-2019 02:21 AM
Please how to setup EasyVPN on RV320 and on Andriod 9 (AndroidOne)?
Should be easy (many tutorials) but it gives this log entries:
2019-03-02, 07:56:02 VPN Log [grpips0][1] 0.0.0.0/0=== ...46.135.4.24===? #1: [Tunnel Authorize Fail] 3DES_CBC is not enabled for this connection. Attribute OAKLEY_HASH_ALGORITHM
2019-03-02, 07:56:02 VPN Log [grpips0][1] 0.0.0.0/0=== ...46.135.4.24===? #1: [Tunnel Authorize Fail] RC5_R16_B64_CBC is not enabled for this connection. Attribute OAKLEY_HASH_ALGORITHM
2019-03-02, 07:56:02 VPN Log [grpips0][1] 0.0.0.0/0=== ...46.135.4.24===? #1: [Tunnel Authorize Fail] CAST_CBC is not enabled for this connection. Attribute OAKLEY_HASH_ALGORITHM
2019-03-02, 07:56:02 VPN Log [grpips0][1] 0.0.0.0/0=== ...46.135.4.24===? #1: [Tunnel Authorize Fail] received Hash Payload does not match computed value
2019-03-02, 07:56:02 VPN Log [grpips0][1] 0.0.0.0/0=== ...46.135.4.24===? #1: [Tunnel Established] ISAKMP SA established
2019-03-02, 07:56:02 VPN Log [grpips0][1] 0.0.0.0/0=== ...46.135.4.24===? #1: [Tunnel Established] received XAUTH ack, established
And Android device says unsuccessful. Already tried to browse forums, updated firmware, deleted easyVPN and phone VPN and entered again.
I've also looked if there are newer routers available (to check if I'm not using very old device that is badly supported) but local eshops seem to offer this router as a main cisco router.
I've tried IPSEC PSK, exactly same text in EasyVPN name in RV320 and in IPsec name on android, tried to leave IPsec name empty, tried to have user in no group and in group of mobile users and still don't know how to access VPN from android.
Thanks for any suggestions.
PS: as I browsed on forums, there is one bug in newest firmware - all entries gets same datetime stamp (e.g. 07:56:02 (even when there is 11:00), prior this 20:48:44 day earlier) but new records are written in log. So analysing that log does not store information is no longer needed - just ignore exact timestamp and look last available.
04-01-2019 06:42 AM
Please does anybody has recommendation? Due to time spend it seems to be best way to throw away this router and buy other one. RV340 that supports anyconnect?
