12-27-2016 04:31 AM
I what to create a VPN-on-demand connection from the iPhone to the RV320. The IPSec VPN is working fine, but I always have to enter the password. I know that the VPN Server (e.g. RV320) needs to allow to store the password on the client.
On the Cisco ASA for example, it needs to be enabled with "password-storage enable".
Is it enabled by default or can this be enabled on the RV320? Which VPN do I need to choose? I'm using EasyVPN at the moment.
Iwan
12-30-2016 01:11 AM
have the exact same issue.
Since I was forced by Apple (iOS 10 update) to use IPSec, as they removed PPTP VPN login.
It's not possible to store the password on the iPhone and always need to re-enter.
This anoying as the password is quite complex and the iPhone itself is password secured.
A fix/solution for this issue is highly appreciated, thanks.
Cheers.
03-07-2017 08:40 AM
Same here. VPN on demand with my iOS 10 iPhone and a complex password to login.
Ist there a solution?
Thanx
